This section Sponsored By
Old 11-03-2009, 05:47 PM
Real Name: Shane
1998 TJ with stock 3.07 gears, I want to change or do I!
I am looking to go from the stock 3.07 gearing to 4.10 or 4.56 gears and 32 or 33" tires. Is it worth the money to change the carrier and gears or find a different axle with the 4.10 gears from a 4 cylinder? I am seeing prices for the carrier at $299 and gears $199 not including the install prices. Would it be an option to add a locker instead of buying a carrier. Sorry, I am new to changing gearing and all this stuff. Any and all help is appreciated. Please welcome me to the forum with kind gestures.
Thanks
View Public Profile Send a private message to %1$s Show hoytpotater gallery
Old 11-03-2009, 07:08 PM
Member
Real Name: glenn
Re: 1998 TJ with stock 3.07 gears, I want to change or do I!
what are you planning to do with the jeep. road/rock/mud or bigger tires?
if you know what you want to do with the jeep then the guys-girls on here can tell you the best set up for your jeep.
p.s i hate to ask but $200 is a little high for one axle gear set and a little low for a set of two? then theres bearings and seals?
View Public Profile Send a private message to %1$s Show glenn beck gallery
Old 11-03-2009, 07:24 PM
HiHood's Avatar
Jeep :
Year :
Lift :
Tires :
CJ-3B
1954
Stock
31"X10.50"X15
Real Name: HiHood
I agree that it depends on what you are going to use it for. If it's a daily driver you wouldn't want to go too low with lockers. Mechanical lockers like Detroits will chew up your tires on pavement so you'ld be best running selectable lockers for a DD. Also, the bigger the tire, the less response the Jeep will have, so there are formulas to figure out what gearing you'll need.
WELCOME TO JEEPZ!!
1954 Willys CJ-3B
****last of the flat fenders****
......ROCK you like a HURRICANE!!!!
. . . F-134 Hurricane, T90 tranny,
. . . Dana Spicer 18 TC,
. . . Dana 44 (rr)Dana 25(frt) 5:38.1
View Public Profile Send a private message to %1$s Show HiHood gallery
  #4 (permalink)
Old 11-03-2009, 10:26 PM
Bounty__Hunter's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
6"
36"
Welcome to the Z. If it's a street jeep, find a set of axles from a '97+ TJ with the 2.5L and 5spd, they will be 4.11 gears.
If you're gonna wheel it, consider a Ford 8.8 rear axle from a '95+ Explorer, they can be found used with 4.11 gears. Have a bracket kit welded on and you're good to go. Then regear the front axle or find an axle from a 4banger.
  #5 (permalink)
Old 11-03-2009, 11:28 PM
TJ_Jeep's Avatar
Jeep :
Year :
Lift :
Tires :
TJ Sport
1998
5"
35" Nitto Terra Grappler
Real Name: Chayse
Location: A little place in the wettest dry county in Alabama
Send a message via AIM to TJ_Jeep Send a message via Skype™ to TJ_Jeep
I have 3.07 with my 35's and it does fine for me, i don't have any problems
My Jeep has a 5th gear??
View Public Profile Send a private message to %1$s Show TJ_Jeep gallery
  #6 (permalink)
Old 11-03-2009, 11:35 PM
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
6"
36"
You report having no problems, yet your sig indicates 5th gear is useless. I'd call that a problem, as well as having to slip the clutch to get going. Not to mention the engine operating below it's prime power range the majority of the time resulting in poor performance and mileage.
  #7 (permalink)
Old 11-04-2009, 12:06 AM
Member
Jeep :
Year :
Lift :
Tires :
TJ Wrangler
1997
Stock
31"
Real Name: Don
yup; I have 3.07s in my 97 TJ as well, and even with only 235/75/15s my 5th gear is borderline useless; it WAS definitely useless, while I had the 31's on there. I have a set of 3.73s and bearings, crush collar etc for the rear; now to wait til I can afford the carrier (hopefully a "Posi"/Sure Grip at least) and the matching gears for the front diff and I'll be swapping them out. as long as my new to driving 16 yo son doesnt tear it up 1st, that is. he's just getting to a point with driving a stick, that I'm letting him drive it w/o me being along for the ride but still needs practice on it.
View Public Profile Send a private message to %1$s Show volaredon gallery
  #8 (permalink)
Old 11-04-2009, 08:24 AM
Real Name: Shane
I use the jeep for mainly hunting only. It's not a daily driver but I do like to drive it on nice cool days to work. I don't need something that is super extreme just want to have something practical for the weekend thing. We have an orv park close that I like to go to with my 4-wheeler and maybe my Jeep.
  #9 (permalink)
Old 11-04-2009, 08:26 AM
Real Name: Shane
The biggest tires I would want would be 33's and might just get 32's and a 2.5" lift.
  #10 (permalink)
Old 11-05-2009, 07:54 AM
TJ_Jeep's Avatar
Jeep :
Year :
Lift :
Tires :
TJ Sport
1998
5"
Real Name: Chayse
Quote:
Thats not really a huge problem for me and i hardly slip the clutch to get it going, running 65mph in 4th is at 1900rpm which i get around 14mpg.
  #11 (permalink)
Old 11-05-2009, 08:00 AM
jps4jeep's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1994
3"
Q's the only TSL
Real Name: Johnny
Send a message via AIM to jps4jeep
Quote:
While I think proper gearing is important, I do agree with this statement. I had 307's with 33's for quite some time, and up here in the hilly north east, driving was not that much different, and honestly the gearing never bothered me... except when off road.
if your not gonna wheel, look for 4cyl junk yard axles. if your gonna wheel, minimum 4.56 with lockers
It used to be a jeep Thing,
But all that stuff broke
-Johnny-
View Public Profile Send a private message to %1$s Show jps4jeep gallery
  #12 (permalink)
Old 11-05-2009, 11:38 PM
TJ_Jeep's Avatar
Jeep :
Year :
Lift :
Tires :
TJ Sport
1998
5"
Real Name: Chayse
I have my 8.8 still waiting to go in with LSD and 4.10 and a 4.10 front gear out of a friends 4 cyl. But it sucks when your jeep is your ONLY vehicle lol.
1998 Wrangler TJ with bad spider gears (?) cromedome CJ YJ TJ and JK 15 12-20-2008 03:17 PM
Rubicon stock 4.10 Gears 06BlueRubi Items for Sale, Trade, or Give Away 0 03-23-2008 07:19 PM
1998 zr2 mufflerman Items for Sale, Trade, or Give Away 0 02-12-2006 02:33 PM
Change dana or change differential ratio? Enzo16 CJ YJ TJ and JK 4 03-16-2005 04:09 AM
Stock gears? TJoffroad00 CJ YJ TJ and JK 9 07-20-2003 08:00 PM
