5" is a lot of coil/spacer height for a short-arm suspension setup. At a minimum you will need longer aftermarket lower control arms to increase the wheelbase and keep the pinion/
caster angles in check.
Many run 5" with a short-arm setup but handling and performance will suffer as the angle of the control arms increases.
