Welcome to Jeepz.com.
Results 1 to 9 of 9
    islandguy89's Avatar
    islandguy89 is offline Member
    islandguy89 is
    has no status.
    Aug 2009
    47
    Type of Jeep
    jeep wrangler islander
    upper half doors ?
    does anyone know if the tj upper door halfs will fit on yj half doors i am in need of some upper door halfs and i cant find any with the rounded corners and the ones that i did find from quadratec are like $300 or if anyone knows where i could get them cheaper that would be great thanx
    CLIMBaMTN's Avatar
    CLIMBaMTN is offline Junior Member
    CLIMBaMTN is
    has no status.
    Nov 2009
    Asheville, NC
    26
    Type of Jeep
    YJ Wrangler
    Re: upper half doors ?
    i don't think they are interchangable.
    I just recieved some YJ upper windows for half steel doors in the mail today, and i found out they do not work with a hard top do to the windows being squared, and hardtop being curved..i wish i had looked closer before buying, i guess now i have a reason to buy a soft top though
    Saddle Tramp's Avatar
    Saddle Tramp is offline Senior Member
    Saddle Tramp is
    in a 12 step Jeepaholic program, again.
    Apr 2009
    Vancouver USA
    610
    Type of Jeep
    CJ-5
    Quote Originally Posted by CLIMBaMTN View Post
    Unfortunately the design of the soft top 1/2 door is different between the YJ & TJ at the top rear of the door. TJs are rounded, YJs are squared.
    black94yj's Avatar
    black94yj is offline Junior Member
    black94yj is
    has no status.
    Nov 2009
    12
    the tj doors will work--not perfect--i just bent the pin that is closest to the latch, out, towards the inside of the jeep--the two front pins line up perfectly--the fab fix is to cut of the pin and fab it up correctly--but this is how i threw them on my jeep--ac
    CLIMBaMTN's Avatar
    CLIMBaMTN is
    has no status.
    Nov 2009
    Asheville, NC
    26
    Type of Jeep
    YJ Wrangler
    ^ I read what you posted in my FS thread...so i need TJ uppers with TJ frames?
    black94yj's Avatar
    black94yj is
    has no status.
    Nov 2009
    12
    i put mine on the other day in a few minutes-i had no uppers and it is starting to get cool in alabama--mine are not fitting perfectly but like i said i threw mine on---but they still look alright--but i did put tj doors on a yj--you can too--let me know how it goes or if i can help--hope this helps--ac
  7. #7
    black94yj's Avatar
    black94yj is
    has no status.
    Nov 2009
    12
    i forgot to tell you that i cut the pins off first i think they were too long--also ground the pins down--they were tight going in the pin inserts--hope this helps--ac
  8. #8
    CLIMBaMTN's Avatar
    CLIMBaMTN is
    has no status.
    Nov 2009
    Asheville, NC
    26
    Type of Jeep
    YJ Wrangler
    i get what you're saying...so using the TJ windows w/ YJ half door should work then? do you know anyone who has that setup? i mean how different could the doors possibly be
  9. #9
    cali_92's Avatar
    cali_92 is offline Senior Member
    cali_92 is
    building his wish list
    Nov 2009
    California
    194
    Type of Jeep
    YJ Wrangler
    my 92 yj has rounded upper doors
    im looking for the squared cornered soft upper cause now i have a gap there.
    its cold and its raining. but what do i kno bout cold its cali.
  1. SOLD!! JEEP WRANGLER Upper Half Doors (TJ OEM NEW) - ATLANTA
    By jtshipp in forum Items for Sale, Trade, or Give Away
    Last Post: 03-27-2005, 07:30 AM
  2. Question about upper hard doors for half doors.
    By Craig in forum CJ YJ TJ and JK
    Last Post: 02-09-2005, 03:03 PM
  3. YJ OEM Soft upper half doors for sale
    By Sparky-Watts in forum Items for Sale, Trade, or Give Away
    Last Post: 04-13-2004, 11:16 AM
  4. In need of upper half doors for jeep
    By mo-james in forum Items for Sale, Trade, or Give Away
    Last Post: 01-22-2004, 06:51 PM
  5. Upper half of Doors Flair Out When Driving on Highway
    By Captaintek in forum CJ YJ TJ and JK
    Last Post: 01-04-2004, 07:01 PM
