My electric choke wont close when cold
Hi all,
I just rebuilt my Carter YF with electric choke and it is behaving so much better but I have one problem left.
My choke is staying in the open position when I go through the initial start up routine. (turn the key on, pedal to the floor one time, start) I took the air cleaner off so I could watch. I was expecting the choke to snap shut but no dice.
When I close the choke by hand, the jeeper starts right up and goes through the high idle cam steps just like it should. Warms up to full open in about 3 minutes.
Should the electric choke spring return the butterfly to the closed position as it cools? Is there an adjustment I need to make?
Thanks!
77 CJ-7 with a 258 and Carter YF with electric choke.
