Page 1 of 3 123 Last
    cali_92's Avatar
    cali_92 is offline Senior Member
    Nov 2009
    California
    195
    Alternator/battery problem
    I drive a 92 jeep wrangler with a 2.5. Long story short alternator bad got a new one got a new battery at the same time old one was bad outdated etc
    My problem is I'm having the same problem as b4 which is the alternator isn't charging my battery and everything is just running off my battery. Resulting in killing my battery and jeep won't start run etc.
    Help. Suggestions please and thank you.
    Tony Fuzi's Avatar
    Tony Fuzi is offline Junior Member
    May 2010
    12
    Have you had your battery tested ? Sometimes when that happens it kills the battery and it won't take a charge .
    cali_92's Avatar
    Nov 2009
    California
    195
    Re: Alternator/battery problem
    New battery haven't had it tested. Going outside right now to take out the battery and altenator to have them tested.
    cali_92's Avatar
    Nov 2009
    California
    195
    But i just bought the battery and altenator yesterday and put it in. The only other thing I can think of is a major draw
    Tony Fuzi's Avatar
    May 2010
    12
    Sorry about that missed the part about the new battery !! Does the gauge show that the alternator is charging ?
    Tony Fuzi's Avatar
    May 2010
    12
    This is a hail marry but once I had a starter with a short that would drain the battery over night !?
  7. #7
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,031
    Loose or dirty connections will do the same thing. Do you have any extras added to the electrical system like lights, amp, radios...? If so how are they connected. Do you have a good ground on both the battery and the alternator?
  8. #8
    cali_92's Avatar
    Nov 2009
    California
    195
    The gauge for the battery shows it slowly depleting meaning it's not charging.
    I could have a bad starter/ with a short imam have to check that next
    I need to locate all the grounds and check them. I do have an amp and sub I kno where that ground is. My radio and amp were shorted out when this all happened had to put new fuses in. Idk if that could help sol e the problem.
    I have the battery charged and tested. And altenator tested today and both r good.
  9. #9
    Jeepkid46's Avatar
    Jeepkid46 is offline Senior Member
    Dec 2010
    Payson, UT
    169
    Quote Originally Posted by cali_92
    Kinda wierd for the bat and alter to die like this but when and whoever put the new radio in may have cut wires and left em bare take the radio out and check all the wires make sure none are bare one wire should come from the dimmer switch to the radio to dim it to but mostly your gauge lights would go out to what fuse blew
    94 XJ- 4.5 RC lift, custom long arm, 242 tcase, 97 engine trans and tcase, 31s on custom painted stock alloy rims, custom rear bumper.
  10. #10
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,031
    Quote Originally Posted by cali_92 View Post
    Few things to check.
    1.) Be sure the connections from the alternator , both power and ground have good clean metal to metal connections.
    2.) With a multi meter measure the battery voltage both with engine off and engine running. report the #'s back
    3.) with the multi meter measure current off the battery. It should be low ( less then 100mA) with the engine off. report back the #'s. If you have a lot of current flow you could start pulling some fuses ( one at a time) to see what circuit is causing the issue. I'd start with any added circuits that go directly to the battery.
  11. #11
    Buck hour's Avatar
    Buck hour is offline Senior Member
    Nov 2010
    192
    Quote Originally Posted by Tony Fuzi
    I had the same problem and it turned out to be a solenoid/ coil problem. This guys gunna need a voltage tester and some spare time! I HATE CHASING SHORTS!! unless they happen to be really short and on a cutie
  12. #12
    cali_92's Avatar
    Nov 2009
    California
    195
    I removed and cleaned and replaced all grounds it didn't seem to help. There were all very clean and tight.
    I did check out the radio wire i do see a few exposed wires so me cut off and just tired up with the rest. Do I just put caps on all of those?
    I don't have a multiple meter so i don't know what to do about that.
  13. #13
    superj's Avatar
    Feb 2010
    texas
    5,428
    5 bucks at walmart and they work as well as the craftsman. i have both and they read the same
    almost done with all the yj stuff.
  14. #14
    Jeepkid46's Avatar
    Dec 2010
    Payson, UT
    169
    It would be easiest to cut off bare wire and tape end with electrical tape
  15. #15
    cali_92's Avatar
    Nov 2009
    California
    195
    Ok this is the whole story if this helps...
    Hit a bump hard on the freeway. Stereo power went in and out until lost all power to it. The interior dash lights went out. Then the RPM gauge, speedometer, and battery gauges went out. It wouldn't start next time i went to start it. Charged the battery, tested alt., alt. Bad, battery ok. Then out in new alt. Had to jump start it, and as soon as i took the pos. jumper cable off it died. Which to my knowledge it should run with even no battery connected. Test the new alt. It was bad got another new one and got a new battery cause old one was fried now. Now with the new alt. Tested good. And new battery. Tested good. The battery is now being drained and i think not charging according to the battery gauge and it dies after driving it a few times.
  16. #16
    Jeepkid46's Avatar
    Dec 2010
    Payson, UT
    169
    bumps and your radio and interior lights should be fixed by those wires hitting a ground now there might be a short to ground between your alt and your bat maybe new wires would do the trick check the continuity of the wires before you buy new ones tho
  17. #17
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,031
    Jeep will not run without a battery. Was this an OEM Alt or aftermarket reman?
    When you cleaned the grounds did you do both sides? Battery and chassis. Alternator and chassis. Engine and chasis. Look at the cables and be sure they are not corroded.
    3.) With the multi meter measure current off the battery. It should be low (less then 100mA) with the engine off. Report back the #'s. If you have a lot of current flow you could start pulling some fuses (one at a time) to see what circuit is causing the issue. I'd start with any added circuits that go directly to the battery.
  18. #18
    superj's Avatar
    Feb 2010
    texas
    5,428
    and make sure you got all the wires back on the alt properly. might have left one off or missed one accidentally
  19. #19
    cali_92's Avatar
    Nov 2009
    California
    195
    took the jeep to have the system checked.
    electrical system is fine when engine off. but confermed that they is a draw when engine is running. thats all the free test included so im back in the same situation. disconected my amp/sun from the battery didnt change anything. im just trying to one by one check everything. checked all fuses. i dont know if i didnt purchase a high enough amperage altenator. thats on 2morrows to do list. all grounds are clean and tight. check most wires and fixed any possible weak connections...
    about to throw in the towel and take it to a shop to have the draw chased.
  20. #20
    Jeepkid46's Avatar
    Dec 2010
    Payson, UT
    169
    I wonder if there is a short around the key or column area
  1. Battery Problem
    By xt master in forum CJ YJ TJ and JK
    Last Post: 12-31-2009, 09:32 PM
  2. Dead battery, Jeep quits, new alternator.
    By Lucihale in forum CJ YJ TJ and JK
    Last Post: 11-28-2008, 08:59 AM
  3. ALternator problem
    By wadesbrain in forum CJ YJ TJ and JK
    Last Post: 08-23-2004, 10:35 PM
  4. Battery or Alternator
    By Deerhunter30 in forum CJ YJ TJ and JK
    Last Post: 10-13-2003, 02:09 PM
  5. Alternator, cables, battery or more...
    By RAVEN13xxx in forum CJ YJ TJ and JK
