    cali_92's Avatar
    cali_92 is offline Senior Member
    Nov 2009
    California
    195
    no low beams/where is my headlight relay?
    92 jeep yj 2.5
    both the low beams on my jeep went out a few yrs go. have just been using brights. its time to fix it. bought brand-new headlamps, installed them didnt fix the problem so i put the old ones back in. tested the connectors to the back of the headlight tested all 3 prongs all good. same on the back of the headlamp was good. could the headlight relay b the problem and if yes. where is it?! i dont see it in my fuse box in the engine compartment or under my dash...
    thanks
    54cj3b's Avatar
    54cj3b is offline Senior Member
    Aug 2009
    Evergreen,Colorado
    1,514
    Re: no low beams/where is my headlight relay?
    check your high/low switch
    ALL I OWN ARE JEEPS!
    54CJ3B ,76DJ5RHD , 81DJ5RHD, 88XJ , (It's)93XJRHD(Alive), 06KJ ,
    cali_92's Avatar
    Nov 2009
    California
    195
    is that the dial next to my headlights switch. doesnt that just adjust my dash lights?
    superj's Avatar
    Feb 2010
    texas
    5,381
    the one on the column, is the one he speaks of, i believe.
    no idea where the relay is though
    almost done with all the yj stuff.
    54cj3b's Avatar
    Aug 2009
    Evergreen,Colorado
    1,514
    High / Low is what changes low and high beams
    the relay should be under the dash along the steering column
    Mikey4x4's Avatar
    Mikey4x4 is offline Senior Member
    Dec 2010
    Kaufman texas
    156
    I had same problem it was high low switch good luck
  7. #7
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    2,911
  1. fog lights and low beams not working
    By rdlcamaro in forum Jeep Electronics and Audio
    Last Post: 11-06-2009, 08:25 AM
  2. right headlight not working, but high beams ot
    By Iglio11 in forum CJ YJ TJ and JK
    Last Post: 06-02-2008, 09:18 PM
  3. starter relay
    By 89cherokee in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 09-13-2006, 05:55 PM
  4. high beams work, low beams won't... what gives???
    Last Post: 06-08-2005, 11:08 PM
  5. 82 CJ7 Relay?
    By derff96963 in forum CJ YJ TJ and JK
    Last Post: 08-19-2004, 07:19 AM
