3 or 4 inch lift?
jayysmith87
I have a 02 jeep x. :d i was wondering if anyone had some pics of there jeep with either a 3 or 4 inch lift with 33" tires. And how hard was the work. I will be lifting it at home with some buddies.
And what are the lift laws in maryland if anyone knows that or if there are any laws in maryland at all about lifting vehicles. :???:
If this is your first lift you are doing, and you can turn a wrench, you can do it.
Sence your jeep is 9 yrs old spray every nut & bolt that you will be removeing with BP for 3 days every day before you start. Read the instructions and make sure you have every tool you'll need.
Take your time, start early, think safety.
Where in Maryland are you?? I'm in Cockeysville (Baltimore) and have a 4" lift (plus 1.25" body lift) on my '06 TJ. 32" tires though...will upgrade to at least 33" if not 35s once these wear out.
