    jersey91yj's Avatar
    jersey91yj is offline Junior Member
    Jan 2011
    3
    91 yj tcase vacuum diagram?
    hey all i'm new here.. just wondering does any1 have a link for a t-case switch vacuum line diagram for a 91 wrangler I6 4.0? my lines hit my exhaust and melted . since the are all black i don't know which 1 goes where. any help is appreciated...thanks.. rico
    rdtj's Avatar
    rdtj is offline Senior Member
    Apr 2010
    194
    Re: 91 yj tcase vacuum diagram?
    just get rid of all the vacume stuff its a hassle anyways
    If my jeep was a woman I would marry it!!!!
    superj's Avatar
    Feb 2010
    texas
    5,486
    which vacuum unit do you have on the front axle and you are carb'd right?
    i just did the lines on the wife's 93, like an hour ago. when you look at the transfer case switch, there are two tangs that make it so you can't put the rubber plug on it wrong. that port between the two tangs is the one that the vacuum line from your manifold goes to. the one straight across from that port is the one for the vent. the other two are your lines for the front axle. when you have the jeep running and the transfer case is in 2h, the line with vacuum goes on the side of the axle vacuum unit that is nearest the wheel. when you put it in 4h or 4l, the line with vacuum is teh line that goes on the port nearest the differential
    almost done with all the yj stuff.
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,256
    Quote Originally Posted by superj View Post
    The '91 is MPFI just like the '93, with the same front axle.
    jersey91yj's Avatar
    Jan 2011
    3
    thanks for the replies.. hey superj. no its not carb'd.. thats why i dont know what is what.. all the air lines coming from the t-case switch are black.. every other diagram i come across always shows colored lines. i guess those are diagrams for carb'd models??
    Nov 2002
    Southern Illinois
    13,256
    from what I've seen the vacuum source from the manifold is a red line, the vent to beneath the battery is a blue line, and the two to the front axle are black lines.
  7. #7
    superj's Avatar
    Feb 2010
    texas
    5,486
    I redid all the ones on the wife's wrangler to black rubber lines. Once you lay ubder it, you'll see how easy it is to swap and what is what
  1. vacuum diagram
    By superj in forum CJ YJ TJ and JK
    Last Post: 01-04-2011, 06:17 AM
  2. vacuum diagram for xj cherokee 1990
    By rmacmt in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 10-28-2006, 11:31 PM
  3. CJ 5 vacuum diagram need help
    By waterdogg in forum CJ YJ TJ and JK
    Last Post: 10-30-2005, 10:02 PM
  4. vacuum diagram
    By VonToth68 in forum Items for Sale, Trade, or Give Away
  5. Weber carb vacuum diagram
    By jay89 in forum CJ YJ TJ and JK
