Old 07-20-2003, 08:00 PM
west747's Avatar
Send a message via ICQ to west747 Send a message via AIM to west747 Send a message via MSN to west747
1057046
will my I-6 258 amc be able to turn 35 inch tires with 4.10 gears efficently??? Just wondering if it will be underpowered.. i looking to buy a set of axles with 4.10 gears already set up in em ...ford 9inch and dana 44...thanks all[addsig]
my junk waiting for Hi-Steer + rear driveshaft
View Public Profile Send a private message to %1$s Show west747 gallery west747
1057051
I´ve never done it to a Jeep, but did have a 3/4 ton Dodge with 36´s and 4.11 gears. Was kind of a dog in low gear, wouldn´t run right, at less than about 1800-2000 RPM (peak torque 2200) and I´m pretty sure you could forget about high gear. Another thing was, when I´d want to stop that thing, from highway speeds, I often felt like I wanted an anchor with me to throw out (forget about panic stops). 3/4 ton brakes where pretty HD but not really up to the job. Finally changed to 33´s 15.50 TSL´s, ran just fine, and pulled a whole lot better in low.[addsig]
DO IT IN THE MUD!
View Public Profile Send a private message to %1$s Show MudderChuck gallery
west747's Avatar
1057144
what would the idle gearing be for an I-6 to run 35 inch swampers?? 4.88, 4.56???[addsig]
  #4 (permalink)
1057151
Jeepgod.com and 4lo.com have some decent tables that might help you out. A rule of thumb, that seems to work out pretty close, is one gear set, for every two inches over stock. 3.73´s or 4.11´s seem to work well with a 31 inch tire. The ideal ratios from my reconing, falls somewhere between 4.56 and 4.88.
Maybe someone who has a bob tail with 35´s could help you out more.[addsig]
DO IT IN THE MUD!
  #5 (permalink)
Member
Send a message via AIM to jprtroy Send a message via MSN to jprtroy Send a message via Yahoo to jprtroy
1057341
I'm running 4:10's with 33" BFG MT's and my max top speed is 63 MPH. With 35' I'll get my top speed back (65 to 70MPH easy). My tire's are brand new, so I'll be swapping out the 4:10's for 3:73's. Running 4:10 with 35"s you'll feel under powered, and loose a lot in your 4lo crawl.
[addsig]
View Public Profile Send a private message to %1$s Show jprtroy gallery
Forum Jump
Message Board Statistics
 Subscribe in a reader
