Welcome to Jeepz.com.
Results 1 to 11 of 11
    Mudjunky's Avatar
    Mudjunky is offline Junior Member
    Mudjunky is
    has no status.
    Jan 2011
    Arkansas
    8
    will a 4" lift be enough?
    Ok guys I have a question I have a '98 sahara with a 4" rough country lift and 33's I just bout a set of 35's on 15x10 wheels will they fit???
    Red Mutt Ranch's Avatar
    Red Mutt Ranch is offline Junior Member
    Red Mutt Ranch is
    has no status.
    Jan 2011
    23
    Yes........... after you cut out every bit of your wheel wells you have and install 2 inch wheel spacers so you can turn. Heck you could stuff 37's with enough saws all blades.
    No you are going to need at least 6 inches of lift and you will still have to get wheel spacers or a set of rims with some extreme back spacing.
    Bounty__Hunter's Avatar
    Bounty__Hunter is
    working on his new WK
    Nov 2002
    Southern Illinois
    12,249
    Type of Jeep
    YJ Wrangler
    Re: will a 4" lift be enough?
    Yes they'll generally fit but they'll rub if you take it offroad. Make sure you have plenty of extra bumpstop length to keep the tires out of the fenders. A 1" body lift will help with clearance.
    The rims should fit depending on backspacing, as with too much backspacing they could rub the spring buckets and the lower control arms.
    sweetpeet's Avatar
    sweetpeet is offline Senior Member
    sweetpeet is
    loving his amc 360 swaped cj5!!
    Apr 2009
    marietta/statesboro, GA
    534
    Type of Jeep
    CJ-5 with AMC 360
    Quote Originally Posted by Red Mutt Ranch View Post
    haha I like the first choice
    Sid1966's Avatar
    Sid1966 is offline Senior Member
    Sid1966 is
    has no status.
    Apr 2009
    Dryden,On,Canada
    154
    Type of Jeep
    TJ Wrangler
    depends on your planned usage,i am running a 2.5 inch susp lift and 2 inch body lift 35x13.50x15 tires on 15x8 rims and 3.25 backspace tires rub on frame and lower control arms off road, can somtimes catch the front sway bar as well can run 38s on the pavement as long as i dont turn full lock on the steering
    Jason4x4's Avatar
    Jason4x4 is offline Senior Member
    Jason4x4 is
    has no status.
    Mar 2006
    701
    Type of Jeep
    TJ Wrangler
    Quote Originally Posted by Mudjunky View Post
    Maybe you should've asked this question BEFORE you bought the wheels and tires?
    But anyway, yeah, they'll fit but you might have some rubbing issues when you're flexing the suspension off road, depending on the offset.
  7. #7
    Mudjunky's Avatar
    Mudjunky is
    has no status.
    Jan 2011
    Arkansas
    8
    Ok thanks fellas gonna try it out tomorrow night thanks for all the help!! I do have another question though if they don't fit could I put a 2" spring spacer lift on top of my 4"?
  8. #8
    Bounty__Hunter is
    Nov 2002
    Southern Illinois
    12,249
    Type of Jeep
    YJ Wrangler
    You can but that's too much combined spring/spacer height for a short-arm designed lift. Simply put, the control arms are too steep and lead to very poor suspension performance onroad and off.
  9. #9
    Mudjunky's Avatar
    Mudjunky is
    has no status.
    Jan 2011
    Arkansas
    8
    Ok could I get adj. Control arms and it work ok or would a body lift just be a better idea?
  10. #10
    Bounty__Hunter is
    Nov 2002
    Southern Illinois
    12,249
    Type of Jeep
    YJ Wrangler
    Adjustable control arms won't help, you would need a long-arm suspension setup for that kind of spring/spacer height.
    Keep your center of gravity low, consider trimming fenders and a small body lift to accomplish the tire clearance.
  11. #11
    Mudjunky's Avatar
    Mudjunky is
    has no status.
    Jan 2011
    Arkansas
    8
    Just gonna let y'all know I got the 35's with 15x10 wheels on my jeep no rubbing!! Even at full turn! Haven't really flexed it much but I did get it stuck in the mud!!!
  1. 2" lift 31" tires 99 Cherokee Sport
    Last Post: 07-22-2011, 10:41 AM
  2. 37" tires 4" lift 2007 JK unlimited???
    By mercab18 in forum CJ YJ TJ and JK
    Last Post: 09-20-2010, 09:56 PM
  3. Big Lift 1989 GMC 4x4 "SOLD"
    By warrior in forum Items for Sale, Trade, or Give Away
    Last Post: 03-05-2004, 02:11 AM
  4. 3" body, 2.5" shackle lift vs. 4" suspension
    By noskils32 in forum CJ YJ TJ and JK
    Last Post: 10-26-2003, 09:57 PM
  5. 3" body, 2.5" shackle lift vs. 4" suspension
    Last Post: 10-25-2003, 07:52 AM
