    Branjmb's Avatar
    Branjmb is offline Member
    Aug 2010
    66
    Rocker Switch Panel.
    Hey guys. So I currently have a very stock Jeep YJ, but in the near future I expect to have offroad lights, lockers, a ford taurus electric fan, etc put in. Obviously all of these will require switches in my cab.
    I am looking to a set of matching rocker switches. However, the complicated part is they will all be using a wide range of voltage, and most rocker switches come with a set max voltage. I need to find a way to have matching switches, but be able to adjust the voltage "settings"
    Does anyone have either a HOW-TO on making this happen or a specific production rocker switch panel?
    Any help would be terrific, please give good instructions or a link to instructions if you can, i don't know too much about wiring, etc.
    Jeep Wrangler '92 YJ
    superj's Avatar
    Feb 2010
    texas
    5,417
    Re: Rocker Switch Panel.
    i am no help but i have heard of people using the rocker panel to run heavier power relays. this way the rocker isn't handling so much amperage and burning out or causing a fire
    almost done with all the yj stuff.
    TLCJ5's Avatar
    TLCJ5 is offline Senior Member
    May 2010
    Homewood,Il
    613
    The way to run a lower amperage switch is with relays....the switch operates the relay with a low amperage ckt....the relay then "switchs" the high amperage ckt to run the accessory. I hear KC lights has a good wiring diagram on their web site,but I seen it myself.
    Tom Landvogt
    1978 CJ5(my toy)
    1999 TJ Wrangler Sahara(daily driver)
    2001 Cherokee Sport(wifes Jeep/winter driver)
    2002 Dodge Dakota(to tow the CJ & Wrangler)
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    3,001
    As stated above, try to run any high (>5A) units thru a relay. Do this for 2 reasons: One is by keeping the switch out you don't have to buy a heavy duty (25A to 30A ) switch. Second the fan could transmit noise thru your cabin and be picked up by a radio or CB.
    Yes KC has some nice diagrams I posted it up here a few times. Yu could search KC for wiring diagram and find several. I posted the general light one.
    Lastly Check Daystar for switches They have some that fit a TJ nicely. Don't know what a YJ stock switch looks like.
    jfrabat's Avatar
    jfrabat is offline Senior Member
    Dec 2006
    San José, Costa Rica
    1,693
    For the original question, contact james at OTRATTW (james@otrattw.com). The ones he uses he sells the body and the rocker separate, and the rockers are labeled. Also, the rockers are compatible with ARB switches, which means if you get ARB, you only need to buy the rocker for it to match. Here's how my switches look (I chose red, but he has many colors):
    And at night:
    Hope this helps!
    Felipe
    '94 YJ 2.5L, Sperwinch EPi 9.0, RE 4" Std Lift, Adv. Ad. SYE, Woody Shafts, Alloy Axles, ARB Lockers, 4.88 gears, 62mm TB & Spacer, 165A Alternator, Griffin 3" Aluminum Rad, Taurus e-fan w/ DC Controller, Borla Cat-Back, Flowmaster hiflow cat, PD Ignition, 19# injectors, Adj. FPR (42PSI), MOPAR cam, Safari Snorkel, 33" BFG KM2, 15" AR wheels, Xenon H4 lights, KC Daylighters & Slimlites, Sony sound, Pavement Ends Targa Top, Hanson Front Bumper, JCR Offroad rear, AtoZ Rockers, Rhino lined Tub.
    Branjmb's Avatar
    Aug 2010
    66
    Very helpful guys thank you!
  1. CJ-7 Rocker panel on a YJ
    By Dittrich31 in forum CJ YJ TJ and JK
    Last Post: 02-13-2011, 10:56 AM
  2. Replies: 0
    Last Post: 02-10-2011, 04:52 PM
  3. question on rocker panel guards
    By wrangleramp88 in forum CJ YJ TJ and JK
    Last Post: 02-18-2009, 07:40 PM
  4. Rocker panel pictures
    By Craig in forum CJ YJ TJ and JK
    Last Post: 10-23-2005, 02:36 PM
  5. Rocker Panel For 1973 CJ5
    By AkoniG in forum CJ YJ TJ and JK
    Last Post: 12-10-2003, 08:23 AM
