    matchbox145's Avatar
    matchbox145 is offline Junior Member
    May 2011
    Florida
    19
    3.7 to 4.10 gears trying to understand ?
    Ok if i want to change my dana 30 and 35 with 3.7 to 4.10 gears i just buy the complete dana 30 & 35 from a jeep that had a 4cy in it and swap them out ? and this will help with off roading and be able to run bigger tires Thanks for your help
    Does not play well with others
    jarbidge09's Avatar
    jarbidge09 is offline Junior Member
    Dec 2010
    8
    Re: 3.7 to 4.10 gears trying to understand ?
    You can also just swap out the gears in the axles with out removing the axles.
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,127
    You want to look for a 4cyl 5spd Wrangler for the 4.10 axles, and '87-'90 rear axles are slightly stronger than the '91-'95 models due to the lack of c-clips and tapered axleshafts.
    My recommendation, find a 4.11 front axle from another YJ, and a Ford 8.8 rear axle with 4.11 from a '95+ Explorer. They can even be found with a limited slip diff, look for 4L10 or 4L11 on the diff tag for the limited slip.
    May 2011
    Florida
    19
    Quote Originally Posted by Bounty__Hunter View Post
    If i found the ford 8.8 what would have to be done to fit my jeep, My jeep is a 89 4.2 5 speed.
    Nov 2002
    Southern Illinois
    13,127
    Just google 'jeep ford 8.8 swap' and you will find tons of info. It's simple and only requires a small amount of welding.
    jps4jeep's Avatar
    jps4jeep is offline Moderator
    Dec 2002
    Boston
    6,655
    are your gears currently 3.07 or 3.73? 3.73-4.10 is not a huge jump. if you can find axles cheap to bolt in as is, then I gues it is worth it, if you need to buy gears and set them up, go deeper than that.
    It used to be a jeep Thing,
    But all that stuff broke
    -Johnny-
  7. #7
    May 2011
    Florida
    19
    Quote Originally Posted by jps4jeep View Post
    My gears are 3.07 and im open to all options
  8. #8
    superj's Avatar
    Feb 2010
    texas
    5,356
    just unbolt your axle assembly and bolt in the 4.10 ones from the 4 banger. easiest way for you if you have no experience
    almost done with all the yj stuff.
  9. #9
    josh94yj's Avatar
    josh94yj is offline Member
    May 2011
    roanoke, tx
    68
    what size tires are you running and what tranny? also you have to change the gear in your t-case for the speedo to match your tire size as well as gears, Quadratec has 2 styles available, some t-case have long shaft gears and some have short shaft gears. i have a 94 4.0 (quite hopped up) and am running 4.56 and lockers front and rear with the NV4500 tranny, and love it! i can pull the tires off the ground from a dead stop with hardly any gas! the torque is awesome, and I have no problem doing 90+ in 5th gear down the highway
  10. #10
    May 2011
    Florida
    19
    Quote Originally Posted by josh94yj View Post
    I'm running 31s for now going to go up to 33s my tranny is the b10
  11. #11
    J Smith's Avatar
    J Smith is offline Member
    Jul 2010
    Grand Junction, Colorado
    36
    Quote Originally Posted by matchbox145 View Post
    Whoa there a minute you guys. You're all putting the horse before the cart a bunch.
    First, we need to know what you plan to do. What size tires are you planning to run? That will tell you about your next step(s). Your tire size will dictate what gear ratio you want to run. Don't change a thing till you have that figured out.
    It might even tell you that you will need some kind of a lift before you need the gears. If you can't run the larger tires, the gears won't matter.
    Go to HappyTrails4wd.com and sign up for the newsletter and Ebook that will give you a really good account of what you need to think about when you want to build a Jeep. There is more to consider than just changing gears and /or axles.
    The axle swaps mentioned above make sense if you plan to really do more difficult trails. If you are just staying in the middle class stuff, you probably don't need to go to that much expense.
  12. #12
    Utah_jeepster's Avatar
    Utah_jeepster is offline Moderator
    Jun 2003
    Tempe, Arizona
    3,480
    3.56-3.90 gears you can run and change no problem, but when you go to 4.10 and smaller you have to change the carrier.
    If you never changed gears in a axle then changing the whole axle housing is the easiest way.
    Because even if both axles are dana 30's changing out the gears will require you to re-set pinion depths and backlash. Also if it is a "C" clip design you need to check axle lash because each differential could be machined differently.
    blatant jokessubliminal sarcasmsexual innuendo
  13. #13
    josh94yj's Avatar
    May 2011
    roanoke, tx
    68
    tire size and torque/horsepower specs in your drivetrain wil all dicate your choice of gears as a whole! you have to know your power range and power rpm range, as well as what you are wanting to use the vehicle for. if you want to crawl you will want MUCH steeper gears, but as a daily driver you will want a choice of gears that offers good offroad as well as on road performance, etc. so you really need to decied what kind of FINAL gear ratio you want to have for the application you plan on using your jeep in 4hi, 4lo and 2hi, in all 4-6 gears in your tranny
  1. Don't understand my problem...
    By the_heffer in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-18-2009, 10:04 PM
  2. 3.07 to 4.88 Gears
    By TJ_Jeep in forum CJ YJ TJ and JK
    Last Post: 02-23-2009, 07:11 PM
  3. It's a Jeep thing... well, I guess you understand
    By PhattyX in forum CJ YJ TJ and JK
    Last Post: 10-08-2004, 07:23 AM
  4. Anyone understand cams?
    By Mxpx182lit in forum General Chat
    Last Post: 09-18-2004, 07:44 AM
  5. Jeeps New Slogan For Those Who Dont Understand
    By TwistedTJ in forum General Chat
    Last Post: 06-04-2004, 03:29 PM
