This section Sponsored By
Old 07-20-2003, 08:00 PM
1058854
Allright, this is my first post and is kind of an urgent request.... :-D
I got my tranny rebuilt .. i guess its the AX-5 (i might be confusing mysefl with AX-15, anyways u guys will know) since i got the 4 bagner... I had the tranny mount replaced but he put some random bolts he found cuz I didnt have the tranny mount bolts....
The bolts worked for a while, but yesterday, i noticed i couldnt get my tranny in 5th and reverse...sorta lick if the tranny had shifted a bit to the right and the shifter now was touching the side of the whole in the floor...I can get it in, but it takes alot of effort...
Then...somtimes my tranny come back to ints original position..Iknow this because all my other gears see me have moved a bit to the right.
I havnt checked yet under the jeep...(snow and cold here in canada...parents buick in my garage.... :-x ) but im pretty shrue that is the problem.... Does somebody know the dimensions of the bolts i need so i could go buy come at canadian tire or the hardware store????...or where i could get this information...Would the bolts be available at the dealer?? :-? (anyawys the dealer is closed during the week end and I was hoping to get this fixed now...
Thanks alot for all your help!!
Dan [addsig]
View Public Profile Send a private message to %1$s Show DannyBlaze gallery
jeepmaster's Avatar
Real Name: Max aka jeepmaster
1058856
blaze on, and id say they messed something up, who did the work? wait for ray and BBJ to come along, ray just did some stuff with his tranny and as i recall black jeep slid his sideways and moved things around a little. so just give them a litlte time and they'll post, oh and it could be a clutch issue, my friend coult barely get his Z28 camaro into first for reverse after pulling his tranny due to a self calibrating clutch or something? he just drove it and eventually it loosened up.
edited by: jeepmaster, Mar 09, 2003 - 12:04 PM[addsig]
Summit County, Colorado - 96 XJ - Magnaflow exhaust, K & N filtercharger, H4 conversion, MT/R's on 767's, safari rack, hot blonde and an Australian Shepherd riding shotgun
View Public Profile Send a private message to %1$s Show jeepmaster gallery
1058858
Thanks Master for replying so quick!!
Well the thing is that...when it goes back in the correct position, the tranny worksd great...im jsut hoping its those damn bolts...i cant afford anythign else!!!haha
ill wait for the boy's and see what that think!!
Thanks dude!!!
:-D [addsig]
  #4 (permalink)
jeepmaster's Avatar
1058859
damn it moves back and forth? thats no good, yea its gotta be the bolts. what kinda wrangler you got?
[addsig]
  #5 (permalink)
1058861
1993 jeep wranger (YJ) 2.5L 5 speed...
has 130 000km wich is really decent millage!!
just got the tranny rebuilt..sio im pretty shure its not an internal tranny problem..im pretty shure its with the installation...
anything else u wanna know?? :-? [addsig]
  #6 (permalink)
west747's Avatar
Send a message via ICQ to west747 Send a message via AIM to west747 Send a message via MSN to west747
1058928
You could always cut the tub a bit to enable the gears to engage....i did this to solve my shifting problem after my lift and t-case drop...however you should prolly try replace the three bolts that hold your t-case to the skid plate.....2 nuts and one tourque bolt out to the farleft....what part of Canada are you from...i reside in New Brunswick...chris :-D :-D [addsig]
my junk waiting for Hi-Steer + rear driveshaft
View Public Profile Send a private message to %1$s Show west747 gallery west747
  #7 (permalink)
Snitty's Avatar
1058949
I am going to say that the bolt that secures the tranny to the skid plate is not in position... or maybe not even there. There should be a small bolt coming down from your tranny through your skid plate... if its not there... you'll have to put one in. you don't want to use a strong one... maybe a grade 2 bolt... this is what keeps your tranny in the center of your jeep... if it is missing, it can allow your tranny to slide over... the reason you should use a weak bolt is because it is intended to break under stress before something else goes. in order to prevent this.. you can strap your tranny so its secured in the center.
If that bolt is there, straight, and in good condition... then you should look at your motor mounts. if one is damaged.. your whole driveline will twist[addsig]
93 YJ 4.0
  #8 (permalink)
1059008
COOL! thanks for all ur help...so basicly that what i tought...the bolts..anybody has any idea of the dimensions ????
Ill probably have to go to the dealer anyways...unless i have the dimensions then i could buy something at a hardware store....
im from quebec ... Aylmer to be precise..rigth next to Ottawa! :-D
Thanks again[addsig]
  #9 (permalink)
1059019
Well first of all the type of jeep you have and year would help some. On my 95YJ the tranny mount is secured to the skid plate with 2 nuts. The mount has studs in it that are not removable and they extend down through the skid plate.
The mount is held on the tranny by 2 bolts. These are probably the ones that are missing/loose. Because the transmission case is aluminum these are REALLY easy to strip out. If they are overtightened they will strip. I think the bolts are 1/2 in diameter but not sure about that.
The only way to tell for sure is to put a jackstand under the tranny and then put a jack under the skid. Then remove the trans mount nuts and the other little one and then the skid bolts themselves (there are six). Then slowly lower the skid and remove it. Then you can inspect the mount bolts themselves and replace if necessary. If they are stripped you might could tap the hole for a larger bolt, if not the tranny will need a new rear case half.[addsig]
View Public Profile Send a private message to %1$s Show RayOvac gallery
 Subscribe to our RSS feed
