1060810
A couple of things, that make it easier is to clean any exposed threads you can with a wire brush (brass) and use a spray oil (WD-40) on most everything before unbolting.
When assembling, donīt tighten down anything (just snug), until all the pieces are on and aligned. Protecting exposed corners with masking tape, and using cardboard spacers (tabs) between seams, saves some scratches.
A little dab of lithium grease on the bolts and screws before assembly, usually makes things alot easier to disassemble in the future.
Many times the body pieces donīt fit just right, the use of some shims or slight seam bending (rubber hammer) may be required.
edited by: MudderChuck, Mar 20, 2003 - 11:13 PM[addsig]
DO IT IN THE MUD!
