TJ Transgo Shift Kit
As a general rule of thumb, all shift kits are bad in a stock transmission. I've never had a stock transmission operate properly for any given amount of time after a shift kit install. If you want to increase the performance of a auto trans with out killing any durability or longevity, look at different stall speeds, proper clutch, band and steel materials etc.. A shift kit only increases line pressure and will prematurely wear your clutches, I've even seen stocks trans with shift kits split a sun gear shells and destroy planetary gears like nothing.
