Transmission woes
Akuhead
Fellas
I hope you can help
I run a Jeep T-176 transmission in a Hotrod. I'm just getting the car road worthy. I had the transmission rebuilt, but left the shift housing alone, as I thought it was OK. In any event, once in a while it won't shift into 3rd or 4th gear. If i go back to second gear, then it seems to shift ok. I just wonder if there is something wrong with the shifter housing somehow and if anyone here has any experience with these things, before I take the shifter housing apart? Any ideas?
Thanks
Jim
Hi Carnuck and thanks for the reply. I think it is in the shift forks and I'll take it apart to see. I also have another shift assy that I can try
Thanks again
Jim
