Welcome to Jeepz.com.
Results 1 to 18 of 18
    Imakrazy's Avatar
    Imakrazy is offline Member
    Imakrazy is
    fixing all minor problems
    Feb 2011
    60
    Type of Jeep
    TJ Wrangler
    Por15 & Herculiner project
    i just bought 2 pints of por15 and a full gallon of herculiner, ive owned 3 wranglers in the past 4 years and i finally just got one with barely surface rust on the frame and a nice body. can anyone with experience give me any advice on what to do with the frame and por15 it. i was originally going to sand it but now i was thinking clean it real good and then por15 it wait a day and herculine on top of it for double protection. im planning on getting underneath and just going to town on everything i see that has some rust or things i know i should protect. Also was curious as to what the outcome of using the herculiner on the flares is. thanks for reading and any advice!
    kingmega's Avatar
    kingmega is offline Senior Member
    kingmega is
    The best part's are the one's the wife never know's about
    Jun 2011
    michigan city IN
    133
    Type of Jeep
    Cherokee
    U could sandblast but will be messy and a pain a good wire wheel on a grinder works well
    Imakrazy's Avatar
    Imakrazy is
    Feb 2011
    60
    Type of Jeep
    TJ Wrangler
    Re: Por15 & Herculiner project
    i think i can get access to a wire wheel but is it neccessary? i want it to be as easy as clean and paint. wishful thinking i guess
    superj's Avatar
    superj is offline Official Supporter
    superj is
    still not gotten the engine swapped
    Feb 2010
    texas
    4,671
    Type of Jeep
    YJ Wrangler
    i thought por15 killed the rust and then sealed the metal, all in one?
    maybe i am dreaming though
    my cycling log
    i figured out how to make a hot link! i am so cool (in my own head)
    bugleboy's Avatar
    bugleboy is offline Senior Member
    bugleboy is
    kinda hungry
    Nov 2011
    Lee County Florida
    1,596
    me and my dad used por-15 on our old charger under the carpet to keep it from rusting, my only advice is to grab sone of this before you start
    its messy stuff and doesent come off easily, but goop definatly helps, also... gloves lol
    69jeepcj's Avatar
    69jeepcj is offline Senior Member
    69jeepcj is
    has no status.
    Feb 2012
    Cincinnati, Ohio
    1,025
    Type of Jeep
    CJ-5
    I did my frame with herculiner, love it! I didn't sand the whole frame down to metal but did take the rusty spot down to metal before painting it. If you have any holes in the frame that you may want to use in the future, you may want to put something in them like a bolt or pencil so they don't get covered up, and then remove before the stuff drys. stir the can often as you apply, everything seems to settle at the bottom of the can pretty fast.
  7. #7
    Imakrazy's Avatar
    Imakrazy is
    Feb 2011
    60
    Type of Jeep
    TJ Wrangler
    Can you upload a pic of the frame so I can see? I'm gonna por15 it then Herculine it because I heard the herculiner will hold water
  8. #8
    Ia2003's Avatar
    Ia2003 is offline Senior Member
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    I used POR-15 on my frame and top coated with POR-15's Chassis Coat Black top coat. I sand blasted it all first. Came out beautifully!
    Attached Thumbnails Attached Thumbnails Por15 & Herculiner project-image-92322880.jpg
  9. #9
    TrailRatedRN's Avatar
    TrailRatedRN is offline Official Supporter
    TrailRatedRN is
    wondering where the gas mileage went
    Aug 2011
    Springboro, Ohio
    1,221
    Type of Jeep
    TJ Unlimited
    I don't quite have the time or skill to remove my jeep from the frame to paint it. lol. Looks good.
  10. #10
    69jeepcj's Avatar
    69jeepcj is
    has no status.
    Feb 2012
    Cincinnati, Ohio
    1,025
    Type of Jeep
    CJ-5
    I won't paint another frame with paint. I have done that in the past, sand blasted, por15, chassis paint, and it got chiped and rubed off while off roading within a couple years. started using bed liner on my frames.
  11. #11
    Imakrazy's Avatar
    Imakrazy is
    Feb 2011
    60
    Type of Jeep
    TJ Wrangler
    I'm thinking por15 and Herculiner will be a goo direction to go
  12. #12
    JohnnyO's Avatar
    JohnnyO is offline Senior Member
    JohnnyO is
    probably drinking coffee
    Sep 2009
    Pittsburgh, PA
    466
    Type of Jeep
    TJ Wrangler
    I painted the whole frame and floorpan on ours with POR-15 last year. My advice is long rubber gloves, a Tyvek suit, and a face shield. If you don't get the paint off your skin with acetone in about three minutes then it will take about two weeks to wear off. Buy cheap paint brushes because you will use one each day. They are not cleanable.
    Steeler Nation does not have to travel. We're already there.
    '97 TJ 4-banger restoration project. My daughter's rig but I buy stuff and tinker with it.
  13. #13
    TerryMason's Avatar
    TerryMason is offline Administrator
    TerryMason is
    too big to fail
    Dec 1999
    Virginia Beach VA
    5,744
    Type of Jeep
    TJ Wrangler
    I'm wearing POR 15 right now on my wrists because I wore normal mechanic's gloves instead of long ones when painting my axle.
    POR 15 is great, but be very careful painting above you. I'd hate to think what it would be like to get this in your eyes.
  14. #14
    Ia2003's Avatar
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    I still have POR-15 on my wrists and arms from a week ago. It's awesome but never goes away.
  15. #15
    TrailRatedRN is
    Aug 2011
    Springboro, Ohio
    1,221
    Type of Jeep
    TJ Unlimited
    LOL. I'm having trouble finding this stuff guys. Where am I supposed to get it?
    RTFO
  16. #16
    TerryMason's Avatar
    TerryMason is
    too big to fail
    Dec 1999
    Virginia Beach VA
    5,744
    Type of Jeep
    TJ Wrangler
    You can get both at amazon
    Amazon.com: por 15
    Amazon.com: herculiner
    In the past I've bought por 15 direct from POR15, Inc. - Stop Rust Permanently - Repair Gas & Fuel Tanks
  17. #17
    TrailRatedRN is
    Aug 2011
    Springboro, Ohio
    1,221
    Type of Jeep
    TJ Unlimited
    I went to 3 different stores and they acted like I was speaking Russian. Went to an auto store, paint store, and hardware store. Lol
    RTFO
  18. #18
    Ia2003's Avatar
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    Www.por15.com
    Www.durabakcompany.com
    Durabak is essentially linex or hurculiner in a wide variety of colors. I am painting the interior of my body tub with it. They will mdil you a free sample to match colors. Most local stores have never heard of these specialty paints.
  1. POR15 and My Beadlocks
    By Dirty-Jeep-Girl in forum General Chat
    Last Post: 06-13-2011, 06:20 PM
  2. project herculiner
    By yjmudder90 in forum CJ YJ TJ and JK
    Last Post: 01-22-2008, 08:07 AM
  3. Herculiner!!....
    By jeeprostyle in forum CJ YJ TJ and JK
    Last Post: 07-16-2004, 09:42 AM
  4. Painting POR15 inside the frame
    By Neia in forum CJ YJ TJ and JK
    Last Post: 04-13-2004, 05:57 AM
  5. Herculiner or not?
    By GEAH in forum CJ YJ TJ and JK
