    HB Jeeper's Avatar
    HB Jeeper is offline Junior Member
    Mar 2012
    7
    CJ5 Measurements
    HI all...Thanks in advance for looking at this. Been having a hard time finding authentic parts for my '74 CJ-5. I am wanting to know if anyone can say that the distance from well to well in the back is the same in a 74 or 76. Trying to get a rear seat but finding it for a 74 is much harder. Same issue for the question below.
    Also is the swing arm/tire carrier the same in dimensions for a 74 over a 76.
    thanks again!
    superj's Avatar
    Feb 2010
    texas
    5,380
    Re: CJ5 Measurements
    Dang, hard to answer questions. I have no idea as i have only seen a cj5 in person so rarely
    almost done with all the yj stuff.
    HB Jeeper's Avatar
    Mar 2012
    7
    Maybe a better question is....are the tubs virtually the same dimensions from the 72-75 Jeeps vs. the tubs on 76-83...
    steady.foot's Avatar
    steady.foot is offline Senior Member
    Oct 2011
    central maine
    519
    Yes. They are the same.
    If you want to drive a sports car, Buy a mustang.
    69jeepcj's Avatar
    69jeepcj is offline Senior Member
    Feb 2012
    Cincinnati, Ohio
    1,817
    Yes, the same. 36" between wheel well to wheel well. Tire carrier should be the same as well. I believe in 76 they started using a longer hood and front fenders but the tubs are the same.
    TLCJ5's Avatar
    TLCJ5 is offline Senior Member
    May 2010
    Homewood,Il
    601
    The longer hood came in "72,also longer wheelbase from 80inches to 83inches.
    The tubs changed in "76,but not the outside dimensions or the width if the cargo/back seat area or the tailgate. Therefore the answer to your original question is indeed 36" in all years. Seats &/or tire carriers are interchangable.
    Just a note: the CJ5 tire carriers swing down not to the side. If you're planning on buying an aftermarket bumper mounted swing out,take measurements to make sure it will clear your tailgate.SOME DON'T clear the CJ5 tailgate. Also a CJ7 factory tire carrier will work with some mount mods to fit the shorter CJ5 tub. Sorry for the wordiness....hope that helps!!
    Tom Landvogt
    1978 CJ5(my toy)
    1999 TJ Wrangler Sahara(daily driver)
    2001 Cherokee Sport(wifes Jeep/winter driver)
    2002 Dodge Dakota(to tow the CJ & Wrangler)
  7. #7
    HB Jeeper's Avatar
    Mar 2012
    7
    Thanks for the information...I really appreciate it.
    Jason
  1. Need measurements
    By Lee3333 in forum CJ YJ TJ and JK
    Last Post: 06-16-2010, 01:56 PM
  2. SOA measurements
    By bpenosa1 in forum CJ YJ TJ and JK
    Last Post: 03-17-2010, 05:53 PM
  3. measurements
    By addotta in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 02-01-2004, 03:02 PM
  4. rotor overall measurements for cherokee sport
    By mrdrac in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 07-24-2003, 10:16 PM
  5. measurements
    By Snitty in forum CJ YJ TJ and JK
