Welcome to Jeepz.com.
Results 1 to 7 of 7
Thread: vacuum lines
    eddie88's Avatar
    eddie88 is offline Junior Member
    eddie88 is
    has no status.
    May 2012
    Pa
    12
    Type of Jeep
    YJ Wrangler
    Question vacuum lines
    Where can I find a diagram for my 89 4.2 vacuum lines after the nutter is done
    carnuck's Avatar
    carnuck is offline Senior Member
    carnuck is
    ASE cert mechanic/partsman
    Jan 2009
    Seattle
    760
    Type of Jeep
    Comanche
    Re: vacuum lines
    I would adjust them similar to a '77 CJ
    Bored with the old one. Need a new one.
    PoliceMonkey161's Avatar
    PoliceMonkey161 is offline Senior Member
    PoliceMonkey161 is
    has no status.
    Dec 2011
    Ellicott City
    355
    Type of Jeep
    CJ-7
    Re: vacuum lines
    I bypassed pretty much everything eventually in order to get the most smooth idle. I eliminated the EGR valve, charcoal canister and the other emissions valves/ports.
    I have a Weber set up and could send you photo's and/or draw diagram if you would like?
    I found this on line and it's a good start:
    superj's Avatar
    superj is offline Official Supporter
    superj is
    still not gotten the engine swapped
    Feb 2010
    texas
    4,633
    Type of Jeep
    YJ Wrangler
    Re: vacuum lines
    i did mine even more basic then the drawing above.
    distributor is run off ported vacuum (but can be run off manifold, your choice) on the carb, 4x4 is run off the manifold vacuum port on the carb. brake booster is run from the normal spot.
    thats all i have and it worked great.
    my cycling log
    i figured out how to make a hot link! i am so cool (in my own head)
    eddie88's Avatar
    eddie88 is
    has no status.
    May 2012
    Pa
    12
    Type of Jeep
    YJ Wrangler
    Re: vacuum lines
    What kind of fuel millage are you getting with the weber carb, my carter is awefull, about 14 on highwau
    PoliceMonkey161 is
    has no status.
    Dec 2011
    Ellicott City
    355
    Type of Jeep
    CJ-7
    Quote Originally Posted by eddie88
    It depends on what jets and air correctors I use and what type of driving I'm planning on. I recently switched to the smaller weber and am getting about 17. I gone as high as 18.5. But Webers are a much more flexible platform because of the jetting kits available. They can be a handful and a lot of guys give up on them because of lack of understanding.
    Even with a Carter you can do better than your current.
  7. #7
    superj's Avatar
    superj is
    Feb 2010
    texas
    4,633
    Type of Jeep
    YJ Wrangler
    Re: vacuum lines
    And 14 is not bad. I was getting 9 with a weber 32. I am up to 13 in town but I am running a four barrel Holley now
    my cycling log
  1. vacuum lines on 90 YJ
    By MORGSTER in forum CJ YJ TJ and JK
    Last Post: 01-20-2012, 12:03 PM
  2. 1980 CJ7 Vacuum Lines
    By JakeNM in forum CJ YJ TJ and JK
    Last Post: 08-30-2009, 12:10 AM
  3. Cj7 78 quadratrac vacuum lines
    By Wildwolf498 in forum CJ YJ TJ and JK
    Last Post: 03-29-2007, 11:11 PM
  4. vacuum lines off of valve cover
    By wm69 in forum CJ YJ TJ and JK
    Last Post: 01-06-2004, 10:32 PM
  5. ......vacuum lines.........
