Welcome to Jeepz.com.
Results 1 to 3 of 3
    insufficient funds's Avatar
    insufficient funds is offline Senior Member
    has no status.
    Mar 2012
    vancouver, WA
    188
    Type of Jeep
    YJ Wrangler
    clutch ticking noise?
    Okay this is a weird one. When the Jeep as at idle and warm there is a ticking noise. When I engage the clutch the sound goes away intill I let the clutch back out. The ticking sounds like a vacuum leak not metal sounding or pinging. ( I know those well lol) is there a vacuume line to the clutch? I belive its only dot3. The clutch was replaced less than 500 miles ago and I had the flywheel resurfaced at the time. 1995 yj 2.5 power house lol I assume ax5. I just replaced the master clutch cylinder about 300 miles ago and the fluid level is good. Help me out guys seen this before????
    95 yj 2.5 power house SOA, procomp 2.5 lift springs, 2” BL, 36x13.50 toyo mts. Locked front Spartan locker, Rear LSD rebuilt packs 80% locked, ford 8.8 rear axle w/ discs, 4.10s , efan mod, k&n intake, 4.ot tb, weighted fly wheel, custom built front and rear bumpers, warn winch, 5k HIDS, led tail lights, Currie SYE, Tom Woods CV drive shaft,
    has no status.
    Mar 2012
    vancouver, WA
    188
    Type of Jeep
    YJ Wrangler
    gennybro's Avatar
    gennybro is offline Senior Member
    gennybro is
    happily twisted
    Oct 2009
    shenandoa valley va
    2,024
    Type of Jeep
    It's gone,waaaaaaaaaaaaa
    Re: clutch ticking noise?
    I don't think it has any thing to do with the clutch,no there is no vacume line to the clutch. The clutch is hydraulicly controlled. It's just your engine,the famous jeep tick,most all of them do it once they get a little age on them.Dont worry about it not unless it starts to go tick tick bang bang. Then I would think you have a problem. When you are pressing the clutch pedal down you are actually takeing a load off the engine,that is why the ticking noise goes away.When the clutch pedal is released the clutch engauges with the pressure plate putting a slight load on the engine.
  1. Ticking noise
    By MattMayTJ in forum CJ YJ TJ and JK
    Last Post: 09-29-2011, 06:31 AM
  2. inline 6 ticking noise
    By mwhite16 in forum CJ YJ TJ and JK
    Last Post: 07-12-2009, 11:16 PM
  3. ticking noise
    By Sly8795 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-03-2005, 03:35 PM
  4. clutch ticking
    By Snitty in forum CJ YJ TJ and JK
  5. Ticking Noise
