Results 1 to 6 of 6
Thread: Jeep TJ Rear Trackbar Bracket
06-14-2012, 04:58 PM #1
Hi, I'm jon and this is my first post here. I have been browsing as a guest for a few months and have learned quite a lot about my jeep. I purchased my 2006 rubicon in november of 2011 and find myself surprised at how excited I am to leave work every day so that I can jump into my jeep and drive around.
I've been getting a very noticeable popping sound from the rear of my jeep when turning and have narrowed it down to this bracket sliding back and forth. Now the bracket has a wide slot for the original bolt and I was curious if this is intended or if its just worn due to not being tight enough. Also when I started tightening it it appeared to be bending the bracket. So I included some pics and was wanting to know if just cranking it down more is an option or if it just needs to be replaced.
Thanks for your time.
06-14-2012, 06:21 PM #2
Looks like its missing the sleeve that is supposed to be on the bigger bolt
See the pics on jks site
http://store.jksmfg.com/merchant2/me...bar_Components
06-14-2012, 06:57 PM #3
Re: Jeep TJ Rear Trackbar Bracket
Ah, just noticed something I didn't see before. It appears that the top horizontal piece of steel in the second picture is buckled. I bet the sleeve you mentioned would have prevented that. I'll make one and try to flatten out that bent bit. A little heat should do the trick.
06-14-2012, 08:50 PM #4
I'd add the sleeve to prevent the bracket from crushing further, and weld a washer over the slotted hole to remove the slop.
06-14-2012, 09:13 PM #5
I think you've got the Rough Country rear trackbar bracket - just like I had. Here's what it should look like:
The bracket worked OK for a while, but I could never keep the bolts tight (even with locktite). I eventually went with the Rough Country adjustable rear trackbar. With our Jeepz.com discount is was only around $100 - Well made and worth the money.
07-04-2012, 11:16 AM #6
Looks like its missing the sleeve.
Recommend an adjustable rear TJ trackbar
By TerryMason in forum CJ YJ TJ and JKReplies: 3Last Post: 05-26-2012, 03:51 AM -
Rough Country Rear Trackbar Bracket (Wrangler TJ)
By TerryMason in forum Product ReviewsReplies: 12Last Post: 11-18-2011, 12:21 PM -
Jeep TJ Rear Trackbar Bracket Install
By TerryMason in forum SuspensionReplies: 2Last Post: 09-21-2010, 03:49 PM -
installed trackbar relocation bracket - problems!!!
By TwistedCopper in forum Cherokee, Commander, Wagoneer and LibertyReplies: 1Last Post: 08-01-2004, 03:46 PM -
XJ 3" lift --> Rear Brake Line Extension Bracket InS
By dingus in forum General ChatReplies: 0Last Post: 07-20-2003, 07:00 PM
LinkBack URL
About LinkBacks
