Welcome to Jeepz.com.
Results 1 to 5 of 5
    signguy's Avatar
    signguy is offline Member
    signguy is
    Reviving an old CJ5
    Oct 2010
    Tonasket WA
    38
    Type of Jeep
    CJ-5
    4.2 L I-6 Re-man
    Under the heading of "Gee, I didn't see that one coming"....
    I was going to rebuild the 4.2L in my '79 CJ 5 this winter. Meant it to be a learning experience for me and my youngest son. The Jeep will be his some day anyway. Then I had a major heart attack last week and things got a little changed around. Still, I think the lad could do the job on his own if I was there to supervise if we were just replacing the old mill with a crate motor. My question is simple; does anyone have any good advice or experience with crate 258 cid motors? I have done a couple of the the old 350 target motors in Chevy pickups years ago. Seemed OK. Any advice would be appreciated.
    Thanks
    69jeepcj's Avatar
    69jeepcj is offline Senior Member
    69jeepcj is
    has no status.
    Feb 2012
    Cincinnati, Ohio
    999
    Type of Jeep
    CJ-5
    Re: 4.2 L I-6 Re-man
    No experience with the crate 258, but something to think about is that all of the AMC v8,s use the same bolt pattern as the 258 and only the drivers side ( I think its drivers side) motor mount needs changed and its a bolt on. Its a total bolt in swap, uses the same harness too.
    superj's Avatar
    superj is offline Official Supporter
    superj is
    still not gotten the engine swapped
    Feb 2010
    texas
    4,633
    Type of Jeep
    YJ Wrangler
    Wow, so you ok then? You're typing so it must be
    my cycling log
    i figured out how to make a hot link! i am so cool (in my own head)
    signguy's Avatar
    signguy is
    Reviving an old CJ5
    Oct 2010
    Tonasket WA
    38
    Type of Jeep
    CJ-5
    Yup... Doin' way better than I deserve! Gonna stick with the old six banger tho', I kinda' like them. I'm sure something will turn up on the Forum here. Thanks.
    0III0forlife's Avatar
    0III0forlife is offline Member
    0III0forlife is
    has no status.
    Mar 2012
    45
    Type of Jeep
    YJ Wrangler
    I put a crate motor in my 87 YJ. 258CID. 4.2L.
    I got it from NAPA, although i'm sure you could find one for cheaper, for $2,000.
    It currently has 12,000 miles on it and it runs great, money well spent.
    The major reason that i went with NAPA, is that i get a Jobber Discount at my local store because i do a lot of business there. And the shipping was taken care of by NAPA. Made quite a difference when having to look at truck freight on 600lbs.
    I put a new flywheel on it, but used all of my old externals, except for the intake, i went with an Offenhauser for that. So that i could mount a Holley 390cfm 4 bbl.
