    ROGLSTUBB's Avatar
    ROGLSTUBB is offline Senior Member
    Apr 2004
    Tulsa,Ok
    213
    2005 TJ O2 sensor and exhaust question
    Its been years since I have been on this forum (sold my zj's 6 years ago) but I figured out my password and I have a quick question. I am considering buying a 2005 TJ with a 4.0. Somebody but a banks monster exhaust and I am thinking they bypassed the o2 sensors. It looks like they have the CEL light out of the dash and when I pulled codes I got four different ones.
    Is this a common modification or did somebody just to a poor job on this. I don't mind fixing it right if thats what it takes. Just been out of the loop on jeeps.
    05 TJ on 32's
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    2,951
    Re: 2005 TJ O2 sensor and exhaust question
    What codes do you have? If they did bypass the O2 sensors then yes you will have CEL codes. if not based on the codes you could narrow it down.
    ROGLSTUBB's Avatar
    Apr 2004
    Tulsa,Ok
    213
    Sorry I don't remember exact codes. But I believe they were o2 sensor heater circuit malfunction. On the chevy's I have had in the last few years there was a fuse caused this code. I checked the owners manual to see if it could be similar but I did find anything.
    I checked autozone website and it looks like there are 4 o2 sensors. I haven't actually crawled under there to see if they are still there. They seem reasonably priced if they are needed.
    I generally like my CEL functional so if I get the jeep I will probably fix so that it does. Just mainly asking if this is "common" modification.
    As now I am thinking about it I should be looking for the catyltic converter as well. Perhaps this is why they messed with o2 sensors
    Catoctin Jeep's Avatar
    Catoctin Jeep is offline Official Vendor
    Aug 2009
    Bel Air, Md.
    212
    To pull your codes up again you do not need a code reader. Turn your ignition off and on three times within 5 seconds or so and the codes will appear on the odometer. When all codes have been displayed "done" will appear on the odometer. You may have already known this.
    The Banks exhaust should be 50 states compliant, therefore all o2 sensors should remain in the stock location. My guess would be that they were never hooked back up or reinstalled in the wrong location. Upstream, downstream. If that is the case, yes you will get the dreaded CEL.
    ROGLSTUBB's Avatar
    Apr 2004
    Tulsa,Ok
    213
    I actually did not know that had changed to the odometer. I was figuring since CEL was out the code reader was the way I would have to check.
    So here are the codes
    Po 135, 141, 155, 161
    Aug 2009
    Bel Air, Md.
    212
    I just checked the codes and all come up as heater failure for one and two sensor. My guess is that the plugs are damaged when reinstalled or one of the wires were melted on the exhaust. Was the exhaust replaced from the engine back or just after the cat. The reason I am asking because there was a point when the new exhaust systems were coming out for these Jeeps and were throwing off the o2 sensors. This maybe the case. I am not sure what the fix was. If you could get the kit number from the owner you could call Banks and asked them if this is normal. But the flag is the heater issue. Just check all the wires and make sure they are in good condition first and go from there.
  7. #7
    ROGLSTUBB's Avatar
    Apr 2004
    Tulsa,Ok
    213
    I just took a better look at the underneath. It looks like stock exhaust all the way back to muffler. All four o2 sensors are in place I did not see a damage to the wires or harnesses.
    Is there a fuse or a relay that controls the heater circuit to them?
    05 TJ on 32's
  8. #8
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    2,951
    O2sensors are known to fail and so do the mini cats. Only put OEM sensors in as other brands cause issues or inconsistent codes. The cat back ic a common mod I have the Banks Cat Back and Borla headders. I also had some bad o2 sensors and a failing cat bank 2.
    Yes there is a fuse.
  9. #9
    ROGLSTUBB's Avatar
    Apr 2004
    Tulsa,Ok
    213
    I went ahead and bought it. Would someone mind telling me what fuse control the o2 sensors. I will get the manual for it on payday. Just curious if could be it being all four sensors throwing a cose
    05 TJ on 32's
  10. #10
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    2,951
    On calif emission vehicles the PDB under the hood uses a 20A fuse in #17. Behind the glovebox Is a 10A in Slot 18.
  11. #11
    ROGLSTUBB's Avatar
    Apr 2004
    Tulsa,Ok
    213
    Ok checked all fuses everything was good. Examined all four o2 sensors and either the car lot I bought the jeep from or PO detailed the sensors or replaced them. They are exceptionally clean. I bought a Haynes manual to check into the 02 sensor heater circuit. The electrical diagram in the book only shows a two 02 sensor setup so it's pretty useless. I was able to find a diagram of the o2 sensor itself online and found the two white wires are for the heater. I checked for 12v at the wiring harness with it running and get nothing. So I am pretty sure this is my problem.
    So does somebody maybe have a better diagram of the four o2 sensor setup?
    05 TJ on 32's
  12. #12
    southtj's Avatar
    southtj is offline Senior Member
    Aug 2003
    Memphis, TN
    3,110
    Not sure if this will help but this is the best I could do from my 04 factory service manual. Click on them to make bigger.
    2005 TJ O2 sensor and exhaust question-tj02a.jpg2005 TJ O2 sensor and exhaust question-tj02b.jpg
  13. #13
    ROGLSTUBB's Avatar
    Apr 2004
    Tulsa,Ok
    213
    I don't think that will work for me. The part numbers for o2 sensors are different from 2004 to 2005. I read online that somebody had a similar problem on a 05 and ended up being ECC. I am starting to think maybe computer controls heater circuits on 2005 and 2006 as they are the same part number 02 sensor.
    Anybody have a FSM for an 05 or 06 can confirm this. Possibly give me some pinouts on the computer to check wiring
    05 TJ on 32's
  14. #14
    ROGLSTUBB's Avatar
    Apr 2004
    Tulsa,Ok
    213
    Just wanted to update this thread with some new info. I bought a FSM online for the 05 TJ and my suspicions were correct the computer on this year controls the voltage to the O2 sensor heaters. I checked the pin outs on computer and I am getting less than a volt to the heater circuits. My best guess is it is the computer that is bad. Just weird everything else would work on it. I will post again when I finally correct the issue
    05 TJ on 32's
  1. Yet another O2 Sensor question.
    By gardengirl38 in forum CJ YJ TJ and JK
    Last Post: 09-24-2010, 02:54 PM
  2. please help.!!!!!!! cam sensor question
    By xjjunkie in forum General Chat
    Last Post: 07-22-2005, 04:04 PM
  3. o2 sensor question
    By Bounty__Hunter in forum General Chat
