Results 1 to 6 of 6
Thread: Rear Oil
07-20-2003, 07:00 PM #1
1064516
Hey guys.....79 cj7 I want to change the oil in the rears.....any pointers on how I should go about this job....and what weight oil is recommended
Thanks[addsig]
07-20-2003, 07:00 PM #2
1064518
when i did mine, i used the 75w-90 gear oil (*because thats what my haynes manual said to use), and it worked fine. had to use a sucker thingy from NAPA to suck the old oil out of the diff (looked more like i was jerking it off... but anyways... :-O ) cost about 5 bucks per axle, definetely a worthwhile investment. the old oil that i sucked out was all old and sludgy looking. quite gross.
-nate[addsig]
07-20-2003, 07:00 PM #3
1064527
rather than sucking it out... i prefer to take off the cover... that way, you get it all out of there, you can clean your gears, and you can inspect to see if everything is alright in there... then use some rtv or similar gasket material to replace it. then just pump it back in, or use a hose to pour it in... you actually do more waiting than anything that way[addsig]
07-20-2003, 07:00 PM #4
1064624
Thanks for the help guys...............Snitty what do you recomend I clean the gears with?[addsig]
07-20-2003, 07:00 PM #5
1064648
brake cleaner, just spray while someone is spinning the tires (on jack stands needless to say) and let it evaporate[addsig]
07-20-2003, 07:00 PM #6
1064807
Use the 75-90 but do yourself a favor use a good synthenic like royal purple, amsoil you will pay a little more but it is worth it.[addsig]
LinkBack URL
About LinkBacks
