Fan Question ?
00Jeep
I've got a 2000 Wrangler 4.0 motor and I would like to pull the clutch fan off and go with a electric had anyone done this and does it work Good ?
Do a web search for "Jeep Taurus Fan" or similar. I run a Ford Taurus fan as well as thousands of other Jeep owners, works great.
I went with the Ford Coutour/Merc Mystique dual fan setup along with a Ford Fuse/Relay PDB to clean up all of the underhood electrics. I wired up the fan for thermostat sensor control, manual override on and manual override off (water crossings). So far so good after the first year
