I ran that tire size on my stock 02 Sahara on the stock Jeep aluminum rims and had no problem with rubbing, even with lock to lock movement of the steering wheel. Clearance was indeed very close, but never a rub including some fairly heavy off roading. I guess my point is that the specific rims are a huge factor as well as the Jeep. A good tire place will mount a set and let you see...do them a favor and buy offset rims from them if they do rub.
