Oil pressure
redneckpyrate
Help please. I just put a new oil pressure switch on my 77 CJ7 258. Now the gauge buries at 80+ psi and doesn't drop after warming up. Should I replace the gauge now?
Got this from anther site:
The oil pressure sending unit is on the engine block and looks like a small 2 X 3 inch filter with one terminal. There may be another sender plumbed in the same area that has two connectors. It is an oil pressure switch that is supposed to close below 4 psi to activate a dash warning light in some speedometer clusters.
To be sure the problem is not the gauge, you can momentarily short the wire from the output of the Sender to ground. If there is no resistance, your gauge should read 80 psi. DO NOT hold it for long in this position. If the needle does not move from zero psi then, either the wiring (open circuit) or the gauge is bad. If it does move, the sender unit is bad.
It is very common for the sending units used with the 258 and 232 engines to be inaccurate. Make sure you have a good connection to the sending unit.
Got this from anther site: The oil pressure sending unit is on the engine block and looks like a small 2 X 3 inch filter with one terminal. There may be another sender plumbed in the same area that has two connectors. It is an oil pressure switch that is supposed to close below 4 psi to activate a dash warning light in some speedometer clusters. To be sure the problem is not the gauge, you can momentarily short the wire from the output of the Sender to ground. If there is no resistance, your gauge should read 80 psi. DO NOT hold it for long in this position. If the needle does not move from zero psi then, either the wiring (open circuit) or the gauge is bad. If it does move, the sender unit is bad. It is very common for the sending units used with the 258 and 232 engines to be inaccurate. Make sure you have a good connection to the sending unit.
Thanks. Looks like I need to buy a new gauge.
