Will 2" Spacers need a TC lowering kit?
BTaylor34
Looking at doing just a simple 2" Rear Coil Spacer lift and a 2.75" on the front (winch weight compensation)
Would I need to lower the TC with that small amount of lift?
You guy's thoughts..
Thanks,
B
Generally no. Drivetrain lengths vary, with the 4.0L auto being the longest. The shorter rear driveshafts increase the chance you'll need a TC drop at lower lift heights. All you can do is try it and see.
You also have the option of using a motor mount lift to improve rear driveline angles.
You can add a 3/4" spacer to the front budget boost to compensate for the winch.
