Wooble ???
00Jeep
I've got. 2000 Tj has a 4" skyjacker lift dual stabilizer shocks new 10" aluminum mod rims with 33x12.50-15 my steering seams quick darty it has the drop pitmen arm that came with lift any ideas ????
#1, Alignment is off, as mentioned
#2, use a stock pitman arm unless you also change the angle of the stock trackbar. Draglink and trackbar must be parallel.
#3, dual stabilizers are not needed, single is plenty
Thanks for Info !! Time to start in on it !
Hey Bounty this is what it looks like with the dropped arm is this right ?
