Turn signals all messed up
Leonard Stokoe
I have a 97 wrangler. The left front turn signal was not working i changed the bulb and still nothing. played with the other bulb and it started working when the bulb was half out. i replaced the turn signal controller now the blinkers flash together and the clock on the radio blinks unless i turn on the headlights then they work correctly on the front but the dash indicaters are still messed up and the clock still blinks.... Any advice ???
Agree with steady.foot . Check for corrosion in bulb socket . Sounds like supply voltage is being back feeded due to a bad ground and wreaking havoc with the body controller .
The indicators are grounded near the headlight under the hood. Start by inspecting and polishing the connections.
