Old 07-20-2003, 08:00 PM
1067198
Most of the time, it runs great. However, I do have problems with starting, both hot and cold. Also, it stalls at ide - 70 MPH.
I put a new battery and did a tune-up with a diagnostic. There were not problems detected, that I am aware of.
Could it be a crank sensor?
Any help I can get is much appreciated.
Byron[addsig]
View Public Profile Send a private message to %1$s Show byron_whitesides gallery
1067204
Also, I forgot to mention, sometimes when I am driving at high speed and it "stalls", I pump the accelerator pedal a couple of times and it starts going again.
I am not sure if that helps.
Byron[addsig]
Member
Send a message via AIM to Jeeper89
1067212
check your fuel filter and it may be your pump....when my jeep had a hard time starting after a week or two my fuel pump when out...but other than that i have really no idea :-D [addsig]
\"I have a \'96 Jeep Wrangler at home in the garage, because I am doing a V8 swap\"---Some Guy
\"You mean a \'95 Wrangler\"---Me
\"No man a \'96 Wrangler\"---Some Guy
A random convosation I had with a man while i was in line buying parts at Auto Zone.
View Public Profile Send a private message to %1$s Show Jeeper89 gallery Jeeper89
  #4 (permalink)
1067214
The fuel filter was checked, yesterday, and cited as being in good repair by the mechanic who performed the tune-up.
I checked the fuel pump, in accordance with the manual, both with the ignition in the "on" position and with the car started. Everything seemed to be in order.
I was just hoping someone would think it was the crank sensor, as it seems like a relatively cheap and easy fix, whereas the fuel pump looks to be costly.
Thanks.
Byron[addsig]
Forum Jump
Message Board Statistics
 Subscribe in a reader
