1997 TJ Power Steering
BamaJeep97
I just purchased a 1997 TJ for my daughter and found that the power steering reservoir has a crack in it and leaks when the fluid reaches the crack. Does anyone know where I get find one? It seems that Chrysler no longer makes the item. Catalog number is 52087 713AB.
Thanks
Hello and welcome to jeepz.com .
Have you tried a local parts store ? I just replaced a power steering pump and steering box on my Cherokee recently and both parts were available in stock . A replacement reservoir may be a special order part ( I.e. Dormans products) but you may find it locally at autozone for instance. If that isn't possible without buying an entire power steering pump , then the auto,recycler may be the only recourse IF the price is right . Please do get your prices first .
I have gone to the website you provided and I have requested the part I need. I will wait the recommended 48 hours to see if I receive a response.
Thank You
