Welcome to Jeepz.com.
Results 1 to 11 of 11
    bermeced's Avatar
    bermeced is offline Junior Member
    bermeced is
    has no status.
    May 2003
    29
    1069607
    About to put a lift on my new jeep, a 1980 cj7. Someone on this site mentioned an inexpensive way to lift a jeep is to use rubber hockey pucks. How much of a lift will that give me? Can you use two pucks together to get a bigger lift? Will I have to do anything else to the jeep, like steering or radiator? If I go this method, what else do I use or do I just use the pucks? And finally, I found six body mounts, three on each side of the jeep. Are there more locations, and where are they, and do they look just like the six I see on the sides? Thanks>[addsig]
    Bounty__Hunter's Avatar
    Bounty__Hunter is
    working on his new WK
    Nov 2002
    Southern Illinois
    12,249
    Type of Jeep
    YJ Wrangler
    1069608
    I recommend using one genuine hockey puck above each body mount for 1" of body lift. I don't recommend stacking them, as it increases leverage on the mount, bolt, and body. You'll need grade 8 bolts 1" longer than stock.
    I think the CJ is similar to the YJ in that there are 11 body mounts. 6 you speak of on the sides, 2 at the rear crossmember, 2 above the gas tank, and 1 beneath the radiator.
    You shouldn't have to modify anything else with a 1" BL.[addsig]
    jps4jeep's Avatar
    jps4jeep is offline Moderator
    jps4jeep is
    typing stuff, right now
    Dec 2002
    Boston
    6,539
    Type of Jeep
    YJ Wrangler
    1069672
    Bounty Hunter,
    When you do a "hockey puck lift" Should you purchase new steel sleeves to put through the puck after you drill it to put the bolt through and reduce wear?
    Johnny[addsig]
    It used to be a jeep Thing,
    But all that stuff broke
    -Johnny-
    jprtroy's Avatar
    jprtroy is offline Senior Member
    jprtroy is
    has no status.
    Dec 1969
    Scotts Valley, CA.
    238
    1069690
    If you only found 6, keep lookin! There are 11 total! One under the radiator, and 4 in the back by the fuel tank.
    Depending on how tall the pucks are, you'll have to lower the radiator by an equevelant amount.
    Remember, that as the body goes up, your shifters won't! If you go too crazy with a body lift, then you have to look at the clutch linkage, and steering linkage.
    [addsig]
    Bounty__Hunter is
    Nov 2002
    Southern Illinois
    12,249
    Type of Jeep
    YJ Wrangler
    1069703
    Bounty Hunter,
    Johnny
    No. The pucks are tough and won't compress too much, and from my experience there is no wear. You benefit from reduced vibrations by adding the pucks, the sleeves will negate this.[addsig]
    monsterrd's Avatar
    monsterrd is offline Senior Member
    monsterrd is
    has no status.
    Feb 2003
    illinois
    305
    1069711
    How long does it take to do the install? 8-) 8-) [addsig]
    Still crazy after all these years !!!!!!
  7. #7
    bermeced's Avatar
    bermeced is
    has no status.
    May 2003
    29
    1069735
    So, will I have to move the radiator if I just go with one puck??[addsig]
  8. #8
    bermeced's Avatar
    bermeced is
    has no status.
    May 2003
    29
    1069736
    A stupid question I am sure, but once I get all the body mounts lose, how do I lift the body off the frame to get the hockey pucks in? Is there a trick to doing this? Should I do one side and then the other, or to I get the whole body up off the mounts? Thanx.[addsig]
  9. #9
    Snitty's Avatar
    Snitty is offline Senior Member
    Snitty is
    has no status.
    Nov 2002
    Olean, NY
    5,646
    1069751
    just get a jack under the body where you want to put a puck.. simple as that.... it seems now that everyone here is gonna go for an inch... its really easy, really cheap, and really effective[addsig]
    93 YJ 4.0
  10. #10
    Mxpx182lit's Avatar
    Mxpx182lit is offline Senior Member
    Mxpx182lit is
    has no status.
    Feb 2003
    Colorado
    383
    1069760
    Me and a friend of mine did a 1 inch puck lift on my TJ in about an hour. The only problem with it was that the radiator fan came into contact with the fan shroud. A little saw work got that all fixed. Hope this Helps!![addsig]
  11. #11
    Bounty__Hunter is
    Nov 2002
    Southern Illinois
    12,249
    Type of Jeep
    YJ Wrangler
    1069765
    My experience with the 1" BL is only with YJ's. No radiator or shroud mods needed on the 4cyl, had to trim the bottom of the fan shroud on the 6cyl. Each app. is different, check the clearances before firing it up.
    Takes about an hour, lot longer if the body bolts are seized in the body.
    • Break all the body bolts loose
    • Remove the radiator body mount bolt
    • Remove the 5 body mount bolts from one side
    • Lift the body from the frame enough to slip the pucks in, I use a floor jack and block of wood
    • Install the 1" longer bolts and tighten slightly
    • Do the same for the 5 body mounts on the opposite side and the radiator support mount
    • Torque all the body mounts once all the pucks are installed
    • Check the radiator, steering shaft, AC lines, and brake lines for clearance
    [addsig]
