This section Sponsored By
Old 07-20-2003, 08:00 PM
1071483
i got a 95 yj just put a 4" rubicon lift on 'em..got a new single steering stabilizer but my steering wheel is cocked different now and i have a little play in the wheel what would be a simple easy fix?I had to move the steering bar(screw it rather) to fit on drop pitman arm,should i have did something different? :-? [addsig]
View Public Profile Send a private message to %1$s Show JeepGurl27 gallery
Bounty__Hunter's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
YJ Wrangler
1995
6"
36"
1071506
You need to lengthen the draglink to recenter the steering wheel. It's the steering link between the pitman arm and the tierod. Loosen both ends and spin the center section to lengthen it.
Something is loose or worn out to cause the loose steering feel.[addsig]
1071757
i will try that bounty hunter thx for the reply ! ;-) [addsig]
  #4 (permalink)
joejeepny's Avatar
1071799
You could adjust the drag link for now but on a four inch lift you should get a drop pitman arm. After you install it you will have to adjust the drag link again.[addsig]
1983 Scrambler-1993 YJ - 2004 rubi
View Public Profile Send a private message to %1$s Show joejeepny gallery
