Old 07-20-2003, 08:00 PM
Send a message via Yahoo to jhiggins
1074005
Ok the jeep is an 88 yj 4.2 ....The problem is when I am driving
the temp stays at the mark above 210, but when I put it 4th gear
it starts to climb until I get the engine around 2000 rpm's, Off-roading
no problem never gets hot, highway it does??? 1st -3rd are fine 4th
and I am driving at highway speeds and then I come to a stop it shoots up
but if I idle the engine at about 1500 rpm's it stays back down around the
mark above 210.. Now 5th gear just forget it, it gets to hot to fast, Why
at higher rpm's is it staying cooler in the lower gears??? ANY HELP PLEASE>>> :-( [addsig]
NEED A TRANNY FOR A 1988 YJ 4.2.....HELP
View Public Profile Send a private message to %1$s Show jhiggins gallery jhiggins
Sully's Avatar
Moderator
Send a message via AIM to Sully
1074008
When you stop at a intersection,does the temp go down???[addsig]
View Public Profile Send a private message to %1$s Show Sully gallery Sully
Member
1074012
Maybe it's the clutch fan. With the hood open have someone or your self turn off the jeep and look and see if the fan keeps turning. If it turns for days and days after it's been turned off i would think that the clutch fan went bad. The same thing happend to me so i just put in a flex-a-lite fan. No more problems.
When your at higher speeds there is more air going though your radiator then at lower speed.
THIS IS JUST MY ADVICE. :-D
edited by: JE420EP, Jun 30, 2003 - 08:41 PM[addsig]
90yj 2.5l 4.5RE EX duty,1\" body lift,33 12.50 BFGKM\"S,Clifford Header,High Flow Kat,K@N FlowMaster,Flex-a-lite Fan,MasterCraftSeats, 4.88\'s, ARB,Full Cage,Currie SYE,Tom Wood CV Driveshaft,JKS Quick Diss.
Real Jeeps Are Built Not Bought!
View Public Profile Send a private message to %1$s Show JE420EP gallery
  #4 (permalink)
1074013
It only goes up at intersections if I have been running 60-65
mph for a little while if not it stays the same temp...
So if I start the jeep and have someone turn it off and the fan keeps
turning the fan is bad??? :-( [addsig]
  #5 (permalink)
Member
1074015
If the fan and the fan clutch is the same unit ya it would be the fan. It's been awhile since i had a stock fan,[addsig]
  #6 (permalink)
1074018
It is all one unit... so What should it stop turning when the
engine is shut off if its good???? :-O [addsig]
  #7 (permalink)
1074026
Just went out and checked it the clutch fan is
fine I shut the engine off and it almost immeadiately
stops spinning .... :-( :-( :-( So its not the clutchfan :-( [addsig]
  #8 (permalink)
Sully's Avatar
Moderator
1074028
Check your coolant levels.[addsig]
  #9 (permalink)
1074029
They are fine all full ....and none is leaking anywhere.... :-D [addsig]
  #10 (permalink)
Member
1074051
I just went thru the same problems. After a new radiator, a new fan clutch, a new water pump, a new temp sending switch in the head, I found out the gauge was a pile of junk. I replaced it with a new aftermarket mechanical one and my temp is a buck 50 to a bock 70. AAAWWW is nice to be able to drive it again without worrying.[addsig]
View Public Profile Send a private message to %1$s Show RedWrang gallery
  #11 (permalink)
1074054
Hmmmm I will try that it always does the same thing
hopefully it is the dumba$$ gauge.... :-D [addsig]
  #12 (permalink)
Utah_jeepster's Avatar
Send a message via AIM to Utah_jeepster Send a message via MSN to Utah_jeepster
1074057
For my two cents I would say replace trhe fan/clutch. The reason is this at higher RPM's the fan is able to pull enough air through to cool the engine and at lower speeds and idle the worn out clutch spins slower drawing less air allowing the temp to rise.
It might not free spin if the clutch is totaly gone but I think its going. and as it gets hot the clutch is slipping.[addsig]
The tricky part is not being able to drive it in....but being able to drive it out.
2001 TJ 4" of lift, long arm kit,ARB's F/R with a viair 450c. Custom front bumper,rocker panels, and sliders.
Only 220 miles to Moab
Only 1622 miles to Red's fridge full of (non-utahian) beer
View Public Profile Send a private message to %1$s Show Utah_jeepster gallery Utah_jeepster
  #13 (permalink)
1074059
Thanks for the input "Utah_jeepster" because right now
I am banging my head on the wall trying to figure out
WHY!!!!!!!!!! I think that is the million dollar question... :-D [addsig]
  #14 (permalink)
1074147
Hey RedWrang where did you get that temp guage and
did it go where your old one was ????
:-D [addsig]
  #15 (permalink)
Member
1074287
I replaced a lot of stuff before i found out that it was the fan. First i had the radiator rebuilt and i another core put in, still overheating, then the thermostat and water pump i went though two water pumps beacuse the first one was bad, still overheating. Then in month later i sad ahhh what about the fan , bought a new fan and all better. For me i just started replacing stuff tell i found it. The jeep has over 100,000 miles on parts like that so i thought that it might be time anyways. [addsig]
  #16 (permalink)
1074414
Well I replaced the clutch fan First and guess what
TADDDAAAAAAAAAAAA whaooo...that's what it was
it runs so nice now and so cool Thanks for all the help guys.... :-D [addsig]
  #17 (permalink)
Member
1074535
Right on! People here can give good advice.[addsig]
  #18 (permalink)
Tug-n-pull's Avatar
Send a message via ICQ to Tug-n-pull
1074536
Glad to hear you have her running cool again! tug[addsig]
View Public Profile Send a private message to %1$s Show Tug-n-pull gallery
  #19 (permalink)
1074543
Me too, I was sweating it in this TeXas heat.. Whewww now
I am ready to go on SUNDAY>>>>> :-D [addsig]
Forum Jump
Message Board Statistics
 Subscribe in a reader
