Old 07-20-2003, 08:00 PM
1040866
I have a 97 TJ with a right rear blinker that does not work. The bulb is completely fine, so i was wondering if it could be a blinker relay. Also, are there seperate relays for each blinker, or are some or all of them combined? If this were the case i believe it must be in the wiring somwhere, however when i turn my alarm on or off the brake light works do i am kinda confused as where to go with this. I it is a relay, where would it be located? Thanks![addsig]
View Public Profile Send a private message to %1$s Show rayzed gallery
1040900
I have/had the same problem on my 91 yj, mine was that in the steering colom the cam that my bliner arm sets in was broke slighty rusted and very loose, it only cost me like 5 dollars from the parts store, check there first i dont know how hard it would be for you since you have a newer model with air bags, but to remove install and put back togerther was like 20 min. hope this helps[addsig]
View Public Profile Send a private message to %1$s Show marc gallery
RAVEN13xxx's Avatar
1040903
Like Marc, I'd look into the switch itself. I believe there is only one relay for the turn signals (I may be wrong, I have a TJ, and it only has one).[addsig]
05 Unlimited Rubicon --- 2\" BDS spacer lift, windshield mounted KC\'s, other mods in the works as funds become available
View Public Profile Send a private message to %1$s Show RAVEN13xxx gallery RAVEN13xxx
Forum Jump
Message Board Statistics
 Subscribe in a reader
