Old 07-20-2003, 08:00 PM
1040937
I have a 95 YJ, 4 banger, auto. 64k miles. When it is cold, the engine idle is rough, then it slows almost to a stall, then comes back to normal.it will cycle this several times. After it gets warmed up for about 1 minute, it seems, OK.
I have changed plugs, wires, cap,rotor, and ran fuel inject. cleaner in it. Any one have any ideas what could be wrong? [img]modules/phpBB_14/images/smiles/icon_confused.gif[/img] thanks in advance. [addsig]
View Public Profile Send a private message to %1$s Show inspector gallery
1040942
Go to a shop that has a diagnostic computer. Check the oxygen and MAP sensor. They could affect your fuel mixture. A vacuum leak would cause it to be bad ALL the time. But the sensors work to find a proper mix and will level out at some point. Good Luck![addsig]
89 YJ 2.5L, 4\" Hell Creek Susp., .5\" homemade lift shackles, 33x10.50 on TJ Grizzly Alloys, Herculined tub, K&N, Dynomax Super Turbo Muffler, Russell extended stainless brake lines, & a Congo Cage w/ Yakima bars
http://coreyandhis.jeepz.com
View Public Profile Send a private message to %1$s Show hi_c gallery hi_c
1040956
If you dont want to go to the shop, take you throttle body off and clean the hell out it, i have a 91 with the 4 cyl, and i had the same prob. while you have your throttle body off clean your Idle Air Control, and space it i think 1/8 of an inch to to that push it in all the way and pull it out, I can almost bet if you do this it will work like a champ, Check your chiltons manual about the space for you I A C but i think its an 8th
good luck[addsig]
View Public Profile Send a private message to %1$s Show marc gallery
  #4 (permalink)
berettajeep's Avatar
Real Name: Dennis
1040957
A 4 banger and auto...I am so sorry [img]modules/phpBB_14/images/smiles/icon_lol.gif[/img] [addsig]
1996 Cherokee Sport 4.0 5 speed 4 in. lift 31's
View Public Profile Send a private message to %1$s Show berettajeep gallery
Forum Jump
Message Board Statistics
 Subscribe in a reader
