Welcome to Jeepz.com.
Results 1 to 8 of 8
    1981CJ5's Avatar
    1981CJ5 is offline Member
    1981CJ5 is
    has no status.
    Aug 2003
    Louisiana
    76
    My fuel gauge and my oil pressure gauge are not working on my '81 CJ5. I think I read somewhere that these two gauges share a common ground. Does anyone know where this ground is? Just want to check all the easy stuff before I buy a new fuel and oil pres. sending unit.
    Thanks. Joel
    hoobness's Avatar
    hoobness is offline Senior Member
    hoobness is
    has no status.
    Apr 2003
    Southern NH
    294
    on my 87, theres a 6" braided ground strap that goes from the top of the head (#5cyl area) to the firewall.
    THe neg term on battery goes to the block (#1 cyl area) just below the alt or (AC if i had it).
    I had simalar probs and by polishing them up with a wire brush it solved the prob
    ndnatty's Avatar
    ndnatty is offline Senior Member
    ndnatty is
    has no status.
    Apr 2003
    Pembroke Pines, FL
    203
    83 CJ AC blower motor.
    Try this site to trouble shoot. But sounds like you blew the fuel guage. http://www.monsterslayer.com/jeep/Gauges.htm. Good luck!
    StockJeepCJ's Avatar
    StockJeepCJ is offline Member
    StockJeepCJ is
    has no status.
    Aug 2003
    Virginia
    31
    You mean to tell me those gauges are supposed to work? **laughs** We have three CJs on the road now and only one has working gauges.
    Neat and clean and very pristine,
    That is what yuppie SUVs are made of.
    Trails and streams and passenger screams,
    That is what real Jeeps are made of.
    OutOfStep's Avatar
    OutOfStep is offline Senior Member
    OutOfStep is
    has no status.
    Sep 2003
    Phoenix, Az
    1,088
    no kiddin, I don't think i've ever seen a CJ that had more than 1 gauge working at any one time
    Nullum magnum ingenium sine mixtura dementiae fuit
    http://www.myspace.com/randallrandazzle
    Tug-n-pull's Avatar
    Tug-n-pull is offline Senior Member
    Tug-n-pull is
    has no status.
    Oct 2002
    East Tennessee
    5,149
    I was just thinking of removeing mine and patching the holes with a some sheet metal and a rivet or two. then draw on new faces and hands set just at the optium setting so I never have to worry about em again. hehehe Tug :wink:
  7. #7
    XJNick's Avatar
    XJNick is offline Senior Member
    XJNick is
    has no status.
    Sep 2002
    Texas
    1,527
    If they stopped working at the same time, definately check the grounds. Also, If they are three wire gauges, check that they are recieving a constant hot as well as the ground.
    -Nick
  8. #8
    far_right's Avatar
    far_right is offline Senior Member
    far_right is
    has no status.
    Nov 2002
    arkansas, or 34*06'N-93*04'W
    2,053
    StockJeepCJ,
    all my gagues work
    82 CJ5 that dont run.... and is no more.... 94 Z71
    J, you wont be forgotten
