11-13-2003, 06:47 PM
Bearings, balljoints, and cv's oh my
Here is the problem The local shop that installs arbs only installs ones they sell, this rules out gettin one on ebay for 400 bucks. Then they want 70 bucks an hour to install them with 14 hours total. Are they that hard to install that they should be done professionally or what.
99 sahara 6.5 inch lift 35s.full Banks exhaust snorkel dana 44 up front super 35 in the rear 4.56s Jeeps Rock.
11-13-2003, 09:28 PM
Real Name: Harry
Not something I would tackle, but I'm sure there will be plenty here that would. What garage are you referring to, E.C.O.H.?
11-14-2003, 04:20 PM
perry hall power equipment
11-14-2003, 10:33 PM
Moderator
14 hours  $980.00 in labor alone, per axle
11-15-2003, 05:23 PM
Real Name: Kenrick
hell nooooo a complets install on an axle shouldnt be that much.... thats alot of labor.... the only hard thing is settin gup back lash for the ring and pinion. well at least thats what i think the hardest is.
hellooo everyoneeee..
'97 TJ, Black, 4" lift w/33x12.50's, Vortec 350, 4L60e, mini spooled dana 44 front, detroit locked dana 44 rear, moser axles and more to come........ Woooo Hoooooooo
11-15-2003, 05:31 PM
Moderator
It shouldn't be that much for 2 axles, at a pro shop.
11-15-2003, 06:59 PM
Moderator
Superior Axle will instal them for about 250 each I think.
11-15-2003, 07:55 PM
Real Name: Harry
Call East Coast Off Road in Harford County for a quote, or there's a 4x4 shop in Glen Burnie that I can't seem to remeber the name of, Maryland 4x4 maybe?
I'd be makin some calls before I put out that kind of coin!!!
11-15-2003, 08:08 PM
there are two things you have to do when installing any type of locker.
One is setting the engagement of the ring and pinion gear. Dykem blue-ing is used to see where the gears mesh.
Second is shimming the locker housing with a dial indacator so you get .051-.070 worth of backlash. Improperly setting either of these will destroy your locker and R/P gears.
A satandard off road shop ( called two localy) will qoute 5 hours per axle. or 250$.
Let your fingers do the walking and call around!
Me thinks your shop is trying to take you for a ride
The tricky part is not being able to drive it in....but being able to drive it out.
2001 TJ 4" of lift, long arm kit,ARB's F/R with a viair 450c. Custom front bumper,rocker panels, and sliders.
Only 220 miles to Moab Only 1622 miles to Red's fridge full of (non-utahian) beer
11-19-2003, 01:39 PM
Member
They wanna bend you over the table! 14hrs? If thats for both axles maybe (that's streching too). I can have my D30 stripped in under 2 hrs! Less time 10yrs ago! (lol) and my rear axle out and axles on the ground in 1.5hr!
As far as the locker install, I don't have the knowledge or tools (got the manual) One of the bearing caps needs to be drilled for the copper air line. If your comfortable working on differentials,and know the in's & out of setting them up, then you could probably do it.
| Thread Tools |
| Display Modes |
Linear Mode
