Old 12-29-2003, 05:28 PM
Send a message via AIM to laneiac
Heres my problem, I have a 95yj with a 2.5 inch rancho lift and a one inch body lift. I experience a small amount of bumpsteer, which I can not stand. I am adding a steering box brace, and considering a steering stabilizer. But can I use a drop pitman arm? I have read in a few places not to use it with less than 3-4" of suspension lift. What do u guys think? I may add shackles with 1/2" lift in the near future. I am currently running 31's and going up to 33's sometime in the next month. Thanks in advance, Lane
View Public Profile Send a private message to %1$s Show laneiac gallery
Old 12-29-2003, 05:51 PM
TwistedCopper's Avatar
Real Name: Harry
The goal is to have your front track bar and your steering drag link (I think that is right, if not somebody correct me!) parallel. if they are or are real close, you probably don't need a drop arm. They are usually recommended for anything over 3". A steering stablilizer helped mine considerably.
Old 12-29-2003, 08:33 PM
Bounty__Hunter's Avatar
Moderator
You are correct on the steering terminology, and the fact that a drop pitman arm is not needed on a 2.5" lift.
What exactly is the jeep doing that you term 'bumpsteer'? It's uncommon in YJ's, especially with that small of lift.
  #4 (permalink)
Old 12-29-2003, 10:08 PM
When I hit any kind of rough terrain on pavement, the steering wheel jumps around. I was thinking it could be a worn steering shaft, but I will try a stabilizer before I get any further into it.
These voices in my head are giving me a headache....
  #5 (permalink)
Old 12-29-2003, 10:54 PM
Moderator
Doesn't sound like bumpsteer. Bumpsteer is when you hit a speedbump that compresses the entire front axle, and the steering wheel is forced to one side. Hold the steering wheel loosely over a speed bump and you'll determine bumpsteer.
Look at the steering shaft where it exits the firewall, just under the master cylinder. There is a clip there that causes a lot of steering wheel movement if it's loose. Grab the steering shaft in the engine compartment and try to shake it.
  #6 (permalink)
Old 01-01-2004, 12:14 AM
joejeepny's Avatar
YJ steering geometry is dumb any how. If you turn the wheel back and forth the tie rod spins before it moves. Gets worse when you lift unless you use a drop pitman. Why did they tie the sterring box tie rod in the middle of the other tie rod. CJ steering the box went to the knuckle. Much better.
1983 Scrambler-1993 YJ - 2004 rubi
View Public Profile Send a private message to %1$s Show joejeepny gallery
  #7 (permalink)
Old 01-01-2004, 12:18 AM
joejeepny's Avatar
What did you do with your track arm. I have a RE2.5 lift and have steering problems. I am going to try a drop pitman this week, And I am replacing the bracket that came with the lift and putting on a new M.O.R.E. products track arm.
  #8 (permalink)
Old 01-01-2004, 01:22 PM
I put a dropped pitman arm in my YJ which has about 1 1/2" of lift from my springs and about 3/4" of lift from my Revolver Shackles up front (2 1/4" total). My dropped pitman arm is rated for a 4" lift and I haven't experienced any problems like reverse bumpsteer.
http://www.cardomain.com/memberpage/475506
- MONEY PIT!!!
- CHEERS TO QUEERS, MORE GIRLS FOR US!!!
View Public Profile Send a private message to %1$s Show Craig gallery Craig
  #9 (permalink)
Old 01-01-2004, 04:37 PM
Moderator
Reader's Rides
Quote:
You think that's bad take a look at XJ and TJ steering, the tow-in changes as the suspension cycles
Sounds like there is a problem somewhere besides needing a dropped pitman arm, the problems you describe are very uncommon with small lifts on YJ's.
You shouldn't have needed to raise the lower track bar mount very much, I just cut and sleeved mine for a 1.5" lift.
  #10 (permalink)
Old 01-01-2004, 09:54 PM
joejeepny's Avatar
TJ's have the same dumb steering as a YJ. The two tie rods are connected in the middle. Just the steering stabilizer is positioned different. They both promote steering wander and bump steer. Someone should make a new knuckle end for yjs to convert them to cj steering.
  #11 (permalink)
Old 01-02-2004, 02:32 AM
Moderator
No, the YJ uses an inverted L design while the TJ uses the inverted Y design. The YJ design does not change toe during the suspension cycle. While you may think both are dumb, they are not the same.
If you want the CJ type it would require a new knuckle or a redesigned steering arm. Some aftermarket kits like MORE high steer would do that.
  #12 (permalink)
Old 01-02-2004, 10:24 AM
joejeepny's Avatar
Took a good look under the new rubicon and your right. The TJ is worst that the YJ. The control are is longer to reduce bump steer but now the tow changes upon travel of the suspension. Thats why the wheel shakes so much when you hit a bump. Where does Jeep get these dumb ideas. Is the high steer product only for SOA YJs.
  #13 (permalink)
Old 01-02-2004, 10:44 AM
joejeepny's Avatar
I found this but i think its only for SOA.
http://www.samsoffroad.com/samsoffroadsto/HighSteer.htm
  #14 (permalink)
Old 01-02-2004, 07:34 PM
Moderator
laneiac, are you any closer to finding what's wrong with your jeep's steering?
  #15 (permalink)
Old 01-02-2004, 10:13 PM
I was gone for the weekend, and tried shaking the shaft like u recommended but it was good and solid... It still feels sloppy and jerks around.... So I am going to try a steering stabilizer and an alignment after I get my new tires... and if that doesnt work then I will try a new steering shaft i guess...
Forum Jump
Message Board Statistics
Jeepz.com RSS2 Feed
