This section Sponsored By
Old 01-13-2004, 06:06 PM
Send a message via MSN to KletusJeeps
Alright fellas I need a little help. As you may know I am tossing the EFI junk and throwing a carb in..I am compiling a list of things I need and what brand to buy this way I can get everything and then do it all at once. Here is what I have so far let me know if I missed anything and feel free to suggest name brands that have worked for you.
(remember this is a 2002 jeep wrangler 4.0 engine)
Cap/Rotor
Carb (Motorcraft 2150)
Intake manifold
Air filter
New fuel filter and possibly a fuel regulator
Did I miss anything?
Kletus
View Public Profile Send a private message to %1$s Show KletusJeeps gallery
Old 01-13-2004, 07:35 PM
clutch and lube ?'s
what kind of jeep do you have? if it has a fuel pump made for efi you need to get that pressure from 35psi or whatever to about 3psi.
i am guessing on this one, but distributor?
anyhow good luck man and that sucks that you couldnt get that efi working, i would have killed for efi!!!
View Public Profile Send a private message to %1$s Show jeep90 gallery
Old 01-13-2004, 07:53 PM
offenhauser makes some pretty good intake manifolds. i'm not sure if the motorcraft is 2 or 4bbl, but i'm also not sure if offenhauser makes 2bbl manifolds.
i've heard using a ford cap/rotor works very well and is good at sealing out water.
you could always make your own snorkle. i use the eddlebrok triangle foam filter. low restriction.
you could also go propane.
i\'m never givin\' up my square headlights and leafsprings, you hear me!? NEVER!
View Public Profile Send a private message to %1$s Show skyjeeper gallery
  #4 (permalink)
Old 01-13-2004, 09:19 PM
www.cliffordperformance.com
take a look at that website, they can setup you up with your carb and intake.
  #5 (permalink)
Old 01-13-2004, 09:21 PM
just thought of something...will the intake manifold for a 258 even fit on your motor?? im not sure
  #6 (permalink)
Old 01-13-2004, 10:27 PM
Speakers
Jeep90 that is the exact question I asked myself when starting to collect parts. I have no idea if an intake manifold from a 89-94 will even fit...
I am researching it now but if anyone knows the quick answer or solution just let me know.
kletus
  #7 (permalink)
Old 01-14-2004, 03:12 AM
Snitty's Avatar
maybe it is just because i'm tired... but is there really a need to change the ignition?
93 YJ 4.0
  #8 (permalink)
Old 01-14-2004, 07:49 PM
Ignition? Why would you say that Snitty? I never thought of it but maybe I am not for sure...tell me your logic behind swapping the ignition..
KLETUS
  #9 (permalink)
Old 01-14-2004, 10:58 PM
how would it work if you were going to go to a carb and ditch the computer with all of the sensors etc... with the older carbed motors you could manually adjust the timing, and had a vacuum advance. isnt the timing electronically adjusted in an efi setup?
and you will need a fuel pump for a carb, i THINK that that would be too much pressure on your fuel lines and too hard on the pump to just install a pressure regulator at about 3psi. on a 30psi+ pump. but im guessing
  #10 (permalink)
Old 01-14-2004, 11:21 PM
jeep90 your right all the timing is electronic this is why I will have to get a distributor, cap, rotor, coil, etc....
I wont be using the flywheel/crank sensor or other electronic sensors or amplifiers so ill have to use the good ol' dependable distributor, cap, rotor, coil, etc...
  #11 (permalink)
Old 01-14-2004, 11:31 PM
that 258 intake manifold will fit on your motor. after reading many articles on the 4.0 head swap for the 258 it should bolt right on. i am very interested in the results of this project because i may be doing that swap on my jeep soon, so please keep us all posted.
  #12 (permalink)
Old 01-15-2004, 03:30 AM
Snitty's Avatar
there are some cooling ports that have to be plugged up to swap the 4.0 head on... otherwise, it should be a bolt on
93 YJ 4.0
