Old 01-17-2004, 07:41 AM
I'm about ready to swap out my tired engine for a rebuilt one and i'm changing the the clutch while im in there and I was wondering what the procedure is to change from an internal to an external slave cylinder. The engine is a 258 and the tranny is a peugeot. The jeep is an '87. Any help would be appreciated. Thanks.
od
View Public Profile Send a private message to %1$s Show odjeep gallery
Old 01-17-2004, 09:48 AM
I would Think you should be able to. You Will have to replace the shift fork to and external one. Is there a whole in the Bellhousing on the side for the fork to come out? If not you might have to replace it with another bellhousing that does have one. Other than that you will have to probably make a bracket to mount the cylinder on the outside. I think that about it. You can pick on a slave cylinder and any parts store for about $20.
82 Jeep CJ7
Engine is 76 258
2 Barrell Intake
Motorcraft 2150 Carb.
Headman Headers
TFI Upgrade
2000 Cherokee Sport
KNN FIPK
View Public Profile Send a private message to %1$s Show derff96963 gallery
Old 01-17-2004, 10:17 AM
Send a message via AIM to GreenReaper93 Send a message via MSN to GreenReaper93 Send a message via Yahoo to GreenReaper93
Yep, I've tried to perform this proceedure. You'll need the shift fork from a '94+ Wrangler, the external slave, throw-out bearing, and bellhousing. The first three parts are easy to find, but the bellhousing in a pain to locate. It should be a direct bolt on.
View Public Profile Send a private message to %1$s Show GreenReaper93 gallery GreenReaper93
  #4 (permalink)
Old 01-17-2004, 10:21 AM
Wait.... I didn't read the peugeot part. Ok, first suggesting would be to scrap that thing. I'm not sure if a '94+ bellhousing will bolt up to that... I was thinking about the AX-15 or AX-5 tranny. Help Guys!
  #5 (permalink)
Old 01-17-2004, 02:51 PM
Snitty's Avatar
if you can get an ax-15 with bellhousing from a late wrangler... it should bolt right up
93 YJ 4.0
  #6 (permalink)
Old 01-17-2004, 03:40 PM
Yeah, what Snitty said! hehe...
  #7 (permalink)
Old 01-17-2004, 09:59 PM
Ok guys, thanks for all the help.
od
\'87 Wrangler, camo paint, nutter bypass, MC carb, 32x9.5 SS TSL on 15\'\' wagon wheels, 1.5\'\' shackle lift, TJ flares, engine driven onboard air.
  #8 (permalink)
Old 01-19-2004, 11:28 PM
Bounty__Hunter's Avatar
Moderator
No can do, there is no external slave setup for the Peugeot BA10/5. The only way it's possible is to swap in a '94+ AX15 with the clutch setup to incude the clutch master cylinder. You'll need to change the transfer case input from 21 spline to 23 spline to match the AX15 output.
You can not use the AX15 bellhousing or external slave parts on the Peugeot.
Forum Jump
Message Board Statistics
 Subscribe in a reader
