I did the exact same swap, I cut the perches and shock mounts right off since I had new ones to put on anyways... but like west said, the xj has a spring over perch and I believe the shock mounts are in a different spot than the YJ needs. One thing that is different is the axle tube breather... on the xj it is off to the side of the brake line t-block. You will just need a new rubber tube to fit onto the smaller fitting on the xj. There is not much else that is different... you may want to check your brake set up on the D44.. when I got mine it had 2.5" brake shoes which are rare i came to find out... the downside is buying new drums for them, they ran me like 70 a piece!
91 YJ 4.0 5spd
SOA + 1.5" reverse eye RE springs
D44 LS Rear 4.56 gears
36"x14.5" Parnelli Jones'
Jks discos
Warn XD9000i
Banks SS exhaust
High Steer!
And a bunch of home made stuff!
