Old 01-25-2004, 11:08 PM
Member
Send a message via AIM to tarsij
OK heres my problem. My transmission went out on my 93 YJ and needs to be replaced. I have the opportunity to buy a 92 YJ for $1000 with a strong transmission and while im almost sure the two transmissions will are the same and can be swapped an idiot mechanic that my mother knows said they cant be. I promised my parents I would find out for sure if they can be swapped. Does anyone (or everyone) tell me if they can be. They are both 4cyls and both 5-speeds. Thanks
TARSI
1993 YJ 2.5L 5-speed
My Jeep Site
View Public Profile Send a private message to %1$s Show tarsij gallery tarsij
Old 01-25-2004, 11:30 PM
Bounty__Hunter's Avatar
Moderator
They can be swapped. The '93 used a different clutch than the '92, so be sure to use all the '92 parts like bellhousing, throwout bearing, clutch, etc.
I've done this many times, so post if you have any questions along the way.
It's likely the '92 isn't that good a tranny since Chrysler recommended the wrong gear oil in every owner's manual and all the trannies have a short life because of it. Much better to find a '94+ tranny so you can also change to an external clutch slave. This requires the '94+ bellhousing, clutch arm, clutch master cylinder, etc.
Lemme know.
Chris
Old 01-25-2004, 11:31 PM
Moderator
Check the flywheel, you may need to use the '92 flywheel.
If you want to keep the '93 flywheel and bellhousing, that may be possible, just make sure the input shafts of the two trannies are identical.
  #4 (permalink)
Old 01-26-2004, 04:16 AM
Snitty's Avatar
my 93 tranny went.. and got a tranny from 91.. the inputs were different... i had to get a pilot machined from bronze because there wasn't the right bearing availible anywhere
93 YJ 4.0
  #5 (permalink)
Old 01-26-2004, 09:28 AM
Moderator
Quote:
Could you have used the '91 flywheel and been okay, or was it a difference the crank of each engine?
  #6 (permalink)
Old 01-27-2004, 03:08 AM
Snitty's Avatar
it was the reciever in the crank
93 YJ 4.0
Forum Jump
Message Board Statistics
 Subscribe in a reader
