Go Back   Jeepz.com > Technical Forums > Everything else
Old 12-19-2003, 01:24 PM
Send a message via AIM to phatyaspen
hwo hard is it to swap a motor into a j20 pickup?what motor fits best for an auto tranny?
super 30 kit w/ arb 5 on 5.5 hub conversion w/ lock outs, TBT hy steer,Currie 60 w/35 spline Detroit w/disc break conversion,Optima red top,Full inatke, Borla exhaust,Jet Chip,AtoZ Stinger, DH fabrication Rear Bumper, Re 4.5" kit w/ 2" spacers
View Public Profile Send a private message to %1$s Show phatyaspen gallery phatyaspen
Old 12-19-2003, 11:15 PM
Tug-n-pull's Avatar
Send a message via ICQ to Tug-n-pull
What came in it and what tranny does it have? Should be no different form any other Jeep with an auto. I would try to replace rather than change due to the work and cost. Tug
View Public Profile Send a private message to %1$s Show Tug-n-pull gallery
Old 12-20-2003, 09:32 AM
Bounty__Hunter's Avatar
Moderator
258/304/360/401 all have the same bellhousing pattern, so it'll bolt right in. You'll need the v8 motor mounts if going from the 258 to a v8.
  #4 (permalink)
Old 01-12-2004, 03:30 PM
redrooster's Avatar
The motor mounts, trans bolt holes etc.. are all the same for the AMC v-8's. The intakes, valve covers, oil pan, pulleys, timing chain cover are all the same. Not sure about th harmonic balancer and flex plate. My memory fails me on that, but you can look at the part numbers in a 4WD Hardware bookk to see if they are different.
The heads and block are not interchangeable (yes you can bolt them up but that changes the compression).
1622 Miles from Moab.
View Public Profile Send a private message to %1$s Show redrooster gallery
  #5 (permalink)
Old 02-06-2004, 09:04 AM
Moderator
Real Name: Chris
Any AMC six or V8 after 1967 will bolt in place of one another. 232-242-258--290-304-343-360-390-401.
View Public Profile Send a private message to %1$s Show Junkpile gallery
  #6 (permalink)
Old 02-27-2005, 01:51 PM
steering pump question
order motor mounts for a chevy small block and go that way. I did motor and tranny in one day not to hard.
View Public Profile Send a private message to %1$s Show 77pickup gallery
Forum Jump
Message Board Statistics
Jeepz.com RSS2 Feed
