    Crusader's Avatar
    Crusader is offline Member
    Jul 2006
    31
    Question--How Much Does My Jeep Weigh?
    Hey Guys:
    I have a 1985 CJ7 with the 6-cylinder engine, and no hard top. The tires, I believe are either 30 or 31 x 10.5 (I don't know for certain, and the Jeep is out of town, otherwise I would check), so they add some weight over the stock tires.
    Can someone tell me approximately what it weighs? The reason I ask, is, I am considering towing it and the maximum towing weight for the hitch is 3500pounds. So, if someone can help me, I would appreciate it.
    Thanks,
    Jim
    mud4feet's Avatar
    mud4feet is offline Senior Member
    May 2004
    Nags Head, NC
    3,909
    Re: Question--How Much Does My Jeep Weigh?
    Don't know if this will help, but here's a link I googled to:
    CJ7 Main Base Page
    I'm thinking you could get a tow-bar and flat tow it, and weight concerns would go away. Otherwise, with the weight of the Jeep and the weight of the trailer, I think you're pushing (or exceeding) the limits of your hitch. Maybe someone else has a more informed answer.
    Just Enjoy Every Possibility!
    yjdave's Avatar
    yjdave is offline Senior Member
    Sep 2003
    portland,OR
    607
    I just got back from flat towing my yj from moab and you dont need to worry bout the weight unless you use a trailer. assuming you have a big enough tow rig. my jeep weights 4500 w/o me or gas, but thats with alot of 2x4 metal and bigger axles and no hardtop. if you have a truck just slap a towbar on her and be gone.
    [IMG]
    currupt4130's Avatar
    currupt4130 is offline VT Hokie
    Jan 2004
    Blacksburg/Williamsburg VA
    2,573
    I can tell you that it's probably close to the weight of your mother in law.
    06 VW (hardcore crawler)
    "The mountains are calling and I must go." -John Muir
    Crusader's Avatar
    Jul 2006
    31
    Sorry, guys, I think I should have been more clear in asking my question. I want to tow the Jeep using a tow bar, which I have (5000# weight limit), and my Dad's Explorer (V8 engine, with I think about a 5000# tow weight limit, too). However, the hitch on the Explorer has the 3500# tow weight limit. So, does that clarification help any with your responses?
    Thanks!
    yjdave's Avatar
    Sep 2003
    portland,OR
    607
    not a problem. the hitch will only see maybe a couple hundred lbs. stopping is always the hard part so just take it easy and all will be fine.
    [IMG]
  7. #7
    cewtwo's Avatar
    cewtwo is offline Senior Member
    Aug 2003
    Englewood, Colorado
    914
    In Colorado, the registration card for the car has the weight at the point of sale on it. It would give you a starting point...
    Did you tell us about your experience in Moab, Dave?
  8. #8
    redrooster's Avatar
    redrooster is offline Senior Member
    Aug 2003
    2,775
    Googled it:
    CJ7 Main Base Page
    Looks to be a bit heavy for a 3500# rated Class II hitch. Best to err on the high side when towing. It would more likely be ok, but is not advised. I would be more concerned with stopping it.
    Nother link for hitch info:
    Receiver Hitch Selection Guide
    1622 Miles from Moab.
  1. Jeep Ignition question
    By dave123 in forum CJ YJ TJ and JK
    Last Post: 12-06-2007, 10:33 AM
  2. question on jeep xj axle shafts
    By xXseekanddestroyXx in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 12-22-2004, 12:29 AM
  3. Unrelated Non Jeep Question about MP3
    By Tug-n-pull in forum General Chat
    Last Post: 10-12-2004, 09:59 AM
  4. Newbe Jeep Question
    By Jeep?_Work\'n_on_it! in forum CJ YJ TJ and JK
    Last Post: 07-24-2003, 10:11 PM
  5. Jeep is now modified, question about posting pic?
    By rtoney9 in forum CJ YJ TJ and JK
    Last Post: 07-23-2003, 09:58 AM
