yea from my research they are pretty much unbreakable. can be shaved so they have more ground clearance they a dana 44 and are stronger and lighter then a corporate 14 bolt.. the only downside i have found about them is the newset ones are still lmost 40 years old(they stopped production in 77 or 7
i read alot of 14 bolt parts can interchange.. i wish i had the 5.14s or the 4.57sn gears but mine has 4.10s in it.. althought with the sm465 granny first i still should be able to get away runniong 40 or 42 inch tires and still have decent power. now i need to figure out how to weld it up. the way the carrier is you cannot see the spider gears at all..
