Welcome to Jeepz.com.
Results 1 to 8 of 8
    jeepin916's Avatar
    jeepin916 is offline Senior Member
    jeepin916 is
    has no status.
    Aug 2003
    NYC
    1,147
    Type of Jeep
    TJ Wrangler
    NeeD Motor Mount Brackets...
    DOES ANYONE KNOW WHERE I CAN GET MOTOR MOUNT BRACKETS?
    hellooo everyoneeee..
    '97 TJ, Black, 8" skyjacker lift w/33x12.50's, Vortec 350, 4L60e, mini spooled dana 44 front, Detroit locked dana 44 rear, moser axles and more to come........ Woooo Hoooooooo
    Bounty__Hunter's Avatar
    Bounty__Hunter is
    working on his new WK
    Nov 2002
    Southern Illinois
    12,249
    Type of Jeep
    YJ Wrangler
    For what?
    Try advance adapters.
    jeepin916's Avatar
    jeepin916 is
    has no status.
    Aug 2003
    NYC
    1,147
    Type of Jeep
    TJ Wrangler
    advanced adapters dont have it, im making my 4cyl TJ to a 6 cyl, 4.7
    jprtroy's Avatar
    jprtroy is offline Senior Member
    jprtroy is
    has no status.
    Dec 1969
    Scotts Valley, CA.
    238
    tj wipers
    M.O.R.E. Bombproof motor mounts. Garanteed to never break!
    Bounty__Hunter is
    Nov 2002
    Southern Illinois
    12,249
    Type of Jeep
    YJ Wrangler
    You're talking about the motor mount perches that weld to the frame, never seen them offered for sale. You'll have to cut some off a junkyard jeep or fab your own.
    They make all sorts of V6 and V8 perches for jeeps, probably a reason for that. There are a lot better cheaper engine options than the 4.7L stroker. If you have to have stroker, go GM 383 v8.
    jeepin916's Avatar
    jeepin916 is
    has no status.
    Aug 2003
    NYC
    1,147
    Type of Jeep
    TJ Wrangler
    hey bounty iv thought of doing an alternative swap like the SBC 350 or the 4.3, but the wiring will be a nightmare to hook up and it wouldnt pass emissions here in NY. thats why i have decided to go with a 4.7 i can use all the stock emissions components, and wouldnt have to deal with wiring my jeep so everything would work.
  7. #7
    Bounty__Hunter is
    Nov 2002
    Southern Illinois
    12,249
    Type of Jeep
    YJ Wrangler
    Don't kid yourself, you'll have a ton of wiring to figure out either way. Makes since though to stick with a jeep engine if emissions is an issue.
  8. #8
    jeepin916's Avatar
    jeepin916 is
    has no status.
    Aug 2003
    NYC
    1,147
    Type of Jeep
    TJ Wrangler
    the wireing isnt that bad at all, have the harness for a 6cyl and all i need to do is plug it up with a new computer..
