Welcome to Jeepz.com.
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 81 to 100 of 116
Thread: 1956 CJ5 Build
  1. #81
    69jeepcj's Avatar
    69jeepcj is offline Senior Member
    69jeepcj is
    has no status.
    Feb 2012
    Cincinnati, Ohio
    998
    Type of Jeep
    CJ-5
    Re: 1956 CJ5 Build
    Is that a brand new vin tag??? If so, where did you get it and can I get one for mine?
  2. #82
    Ia2003's Avatar
    Ia2003 is offline Senior Member
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    Yes, it is a brand new VIN tag. You can get them at www.kaiserwillys.com . I took it to my local trophy / award shop and had them engrave my VIN on it.
  3. #83
    Ia2003's Avatar
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    The engine starts with the new SOLEX carb but will only run for a few seconds. I have seen other threads about the Solex carb crapping out right after starting. I'm sure it's a choke and adjustment issue but the carb didn't come with any instructions. Any ideas how to adjust it?
  4. #84
    Ia2003's Avatar
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    Body work is progressing slowly but surely. The grill is complete and will be mounted this week. The rusted side panel was removed from the body and the new panel has been installed, going to be welded in this week. I am using POR-15's "Hardnose" paint in black. This stuff is indestructible. It is immune to rust, humidity, cracks, chips, etc. plus it looks really good!
    Attached Thumbnails Attached Thumbnails 1956 CJ5 Build-image-132972594.jpg   1956 CJ5 Build-image-1173134463.jpg
  5. #85
    Ia2003's Avatar
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    I mounted the grill to the radiator today. I had to cut off about 6 inches from both radiator hoses to get everything to fit right. In that process I had a somewhat severe leak of radiator fluid. Hence the pile of kitty litter on the floor. I sanded the headlight surrounds, prepping them for POR-15. I will be installing headlights, marker lights in the next few days.
    Attached Thumbnails Attached Thumbnails 1956 CJ5 Build-image-2180281586.jpg   1956 CJ5 Build-image-3472255580.jpg
  6. #86
    gennybro's Avatar
    gennybro is offline Senior Member
    gennybro is
    happily twisted
    Oct 2009
    shenandoa valley va
    1,839
    Type of Jeep
    It's gone,waaaaaaaaaaaaa
    Re: 1956 CJ5 Build
    Hell yeah, glad to see it comeing togeather.
  7. #87
    Ia2003's Avatar
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    Headlights and marker lights installed and wired. I got two new low back tan seats from Rugged Ridge. I painted the seat frames with POR-15 and mounted the drivers seat to the frame today, passenger seat tomorrow.
    Attached Thumbnails Attached Thumbnails 1956 CJ5 Build-image-2796793454.jpg   1956 CJ5 Build-image-3987810619.jpg
  8. #88
    Ia2003's Avatar
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    Headlights wired.
  9. #89
    Ia2003's Avatar
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    Body tub complete and primed. It has two new side panels. Substantial welding work was done to put the letters, gas tank opening and soft top bow indents into the new panels from the originals. Nobody makes entire side panels fir early CJ5's. Applying POR-15's "hard nose" paint in gloss black tomorrow.
    Attached Thumbnails Attached Thumbnails 1956 CJ5 Build-image-1533143152.jpg   1956 CJ5 Build-image-1396417033.jpg
  10. #90
    SteelHeadz's Avatar
    SteelHeadz is
    in need of gears for the front and rear axles. ;(
    Oct 2008
    Kerrville, TX
    5,839
    Type of Jeep
    CJ7/ AMC 360
    Re: 1956 CJ5 Build
    Looking really nice!!!
  11. #91
    Ia2003's Avatar
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    Thanks! It's coming along!
  12. #92
    Ia2003's Avatar
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    Body tub and windshield frame sanded and prepped for paint.
    Attached Thumbnails Attached Thumbnails 1956 CJ5 Build-image-151679665.jpg   1956 CJ5 Build-image-4024325121.jpg
  13. #93
    Ia2003's Avatar
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    The body tub is complete. I sprayed it with POR-15's "Hardnose paint" and painted the interior and undercarriage with Durabak-18 coating. It turned out very nicely. I also sprayed the windshield frame and tailgate. Fenders and hood are next.
    Attached Thumbnails Attached Thumbnails 1956 CJ5 Build-image-1717903049.jpg   1956 CJ5 Build-image-2071958456.jpg
  14. #94
    sweetpeet's Avatar
    sweetpeet is offline Senior Member
    sweetpeet is
    loving his amc 360 swaped cj5!!
    Apr 2009
    marietta/statesboro, GA
    534
    Type of Jeep
    CJ-5 with AMC 360
    Quote Originally Posted by Ia2003
    After two weeks at the sand blast shop, I finally got the frame back. It looks really good! I applied two coats of POR-15 (pictures to follow). Once all the rust was removed I uncovered the original serial number from the frame (101295). This tells me the frame is from 1955 if it's a true CJ5 frame. It can be from another early CJ from another year but I don't know how to verify its a true CJ5 frame. I also uncovered the engine serial number while disassembling the engine. It is 800885. That number is a 1958 CJ5. Any ideas on why there is a difference in serial numbers? I've been trying to figure out this jeeps true birth year for over a year.
    Not sure if this has been answered or not. It's a bass-turd, by the most literal definition. I also have a cj5 and have found that most cj5s that still exist today have been mixed and matched to be kept alive. So don't be suprised if you see more of this in the engine, tranny, original body color, etc...
    I really like the build! I wish I'm not done building mine so I'm def gonna use this a bit as a reference.
    Oh one more thing, why did you go with the t-90 three speed. I've got the three speed and I hate the thing... I'm thinking bout changing to a 5speed. Was it just because of cost?
  15. #95
    Ia2003's Avatar
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    Thanks! I have found that much of my Jeep has been mixed and matched. I kept the T-90 for two reasons. First off, starting out on the build I did. It know a whole lot about early CJ5's. I learned everything throughout the course of this build by taking it apart, doing research and getting info from here. I did not really know what a dog the T-90 was. Second, the goal of this build was to restore the Jeep to as close to original configuration as possible. I see plenty of old Jeeps out there chopped up and lifted but it is rare to see a stock looking Willys.
  16. #96
    Ia2003's Avatar
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    Body tub mounted on the frame.
    Attached Thumbnails Attached Thumbnails 1956 CJ5 Build-image-3264453373.jpg   1956 CJ5 Build-image-3377678208.jpg
  17. #97
    Ia2003's Avatar
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    Now that the tub is on I am installing lots of parts. Steering wheel, tail gate, mirrors, turn signal lever, data plates, etc.
    Attached Thumbnails Attached Thumbnails 1956 CJ5 Build-image-2819915465.jpg   1956 CJ5 Build-image-1915033325.jpg
  18. #98
    Ia2003's Avatar
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    All body components. Except the hood installed. Tail lights, gas tank, air cleaner, fuse block installed.
    Attached Thumbnails Attached Thumbnails 1956 CJ5 Build-image-3034478876.jpg   1956 CJ5 Build-image-97855448.jpg
  19. #99
    Ia2003's Avatar
    Ia2003 is
    has no status.
    Mar 2011
    Columbus, GA
    113
    Type of Jeep
    CJ-5
    Drivers seat installed. Put the first few miles on it test driving around the block. Tuned the carb and it now runs beautifully. Next up is passenger seat, finish wiring lights and gauges.
    Attached Thumbnails Attached Thumbnails 1956 CJ5 Build-image-745983798.jpg   1956 CJ5 Build-image-544334510.jpg
  20. #100
    54cj3b's Avatar
    54cj3b is offline Senior Member
    54cj3b is
    Tired of having cancer
    Aug 2009
    Evergreen,Colorado
    1,524
    Type of Jeep
    Willys cj3b
    Re: 1956 CJ5 Build
    Nice job Ian looks great!!
    ALL I OWN ARE JEEPS!
    54CJ3B ,76DJ5RHD , 81DJ5RHD, 88XJ , (It's)93XJRHD(Alive), 06KJ ,
  1. 1956 Willys CJ5 for sale
    By Ia2003 in forum Items for Sale, Trade, or Give Away
    Last Post: 10-16-2011, 11:35 AM
  2. 1956 CJ5 Fuel system replacement
    By Ia2003 in forum CJ YJ TJ and JK
    Last Post: 04-13-2011, 03:22 PM
  3. Buy or build my 2.5 ?
    By piratessoul in forum CJ YJ TJ and JK
    Last Post: 05-20-2010, 03:09 PM
  4. YOU Build MY YJ...
    By Boze in forum CJ YJ TJ and JK
    Last Post: 01-24-2009, 02:05 AM
  5. GTO build up
    By Greencuke in forum General Chat
    Last Post: 03-27-2007, 02:25 PM
