Radio - Jeepz.com
Forum Reader Rides How-to Section Register Site Map
Go Back   Jeepz.com > Technical Forums > Jeep Electronics and Audio
LinkBack Thread Tools Search this Thread Display Modes
Old 05-11-2009, 11:07 AM
CAnderson1034 has no status.
Jeep :
Year :
Tires :
CJ-5
1979
Mickey Thompson MTZ 31x10.50x15
Real Name: Clint Anderson
Radio
I have a 79 CJ5 and I am wanting to put a new radio in it, but can't hardly seem to find anything. Any ideas?
View Public Profile Send a private message to %1$s Show CAnderson1034 gallery
Old 05-11-2009, 12:07 PM
SteelHeadz's Avatar
SteelHeadz is getting older
Moderator
Jeep :
Year :
Lift :
Tires :
CJ7/ AMC 360
1981
4.5
35x14.5 15 Pittbull Krawlers
Real Name: Mikey
Send a message via MSN to SteelHeadz Send a message via Yahoo to SteelHeadz
Re: Radio
If your looking for the original setup where there's 1 knob on both sides of the dial, try this link. absolute classics - Making Yesterday's Cars Sound Great Today .
If you want an updated one , you can cut the opening of the dash to a rectangular opening OR get a marine radio box and mount it under the dash with 2 brackets.
View Public Profile Send a private message to %1$s Show SteelHeadz gallery
Old 05-11-2009, 02:59 PM
Jeep :
Year :
Tires :
CJ-5
1979
Re: Radio
Thank you. Any recomendations on marine radios?
  #4 (permalink)
Old 05-11-2009, 03:23 PM
SteelHeadz's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
CJ7/ AMC 360
1981
4.5
Real Name: Mikey
Re: Radio
I'm using a Pyle marine am/fm aux/mp3 cd player with a remote head. It's been through a lot of rain before i installed the top on it and it's still going. There's quite a selection of marine radios out there now that i would consider if this thing would just blow up. 4WDHardware and Quadratech has some selection of marine radios. http://www.4wd.com/productdetails.aspx?partID=42092
  #5 (permalink)
Old 05-15-2009, 10:46 AM
Jeep :
Year :
Tires :
CJ-5
1979
Re: Radio
Thanks for all the help but the radio has been put on hold due to the motor issues. When I do get back to it I think I am going to go with the marine radio. Once again thanks.
  #6 (permalink)
Old 05-24-2009, 08:36 AM
jimpatalano has no status.
Jeep :
Year :
Lift :
Tires :
JK Wrangler
2008
Stock
Stock
Real Name: jim patalano
Re: Radio
where can I find out how to remove my 2008 radio
View Public Profile Send a private message to %1$s Show jimpatalano gallery
  #7 (permalink)
Old 05-24-2009, 08:54 PM
SteelHeadz's Avatar
Moderator
Jeep :
Year :
Lift :
Tires :
CJ7/ AMC 360
1981
4.5
Real Name: Mikey
Re: Radio
Quote:
REMOVAL
WARNING: On vehicles equipped with airbags, (refer to electrical/restraints) before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Failure to take the proper precautions could result in accidental airbag deployment and possible personal injury.
NOTE: For REQ radios, turn ignition to RUN and press the SET + SCAN buttons simultaneously to place the radio into transportation mode. The radio will display "Transportation" on the display within 5 seconds. If the radio is inoperative or not REQ, skip this step.
1.Disconnect the battery negative cable.2.Remove the center bezel.(Refer to 23 - Body/Instrument Panel/BEZEL, Instrument Panel - Removal) .3.Remove the radio mounting fasteners.4.Pull out the radio and disconnect the electrical and antenna connectors.5.Remove the radio.
REMOVAL
1.Using a trim stick C-4755 or equivalent, release the clips (2) and rotate the lower center trim (3) down and release the tabs (1).
2.Using a trim stick C-4755 or equivalent (2), release the clips in the rear of the upper trim (1).
3.Rotate the upper trim (2) back and release the front (1).
4.Disconnect the electrical connector (4) and remove the upper center cover (1).
5.Remove the screws (2) and using a trim stick C-4755 or equivalent, separate the center bezel (1).
6.Disconnect the HVAC control cables (1 and 9) and disconnect the electrical connectors (3).
7.Remove the screws (2) and remove the center I/P trim panels (1 and 3).
Search this Thread:
Advanced Search
radio rookiejeeper12 CJ YJ TJ and JK 5 01-30-2009 08:46 AM
cb radio??????? 88WRANGRED General Chat 7 08-07-2003 02:15 PM
radio help bluejeeper CJ YJ TJ and JK 5 07-20-2003 07:00 PM
Radio Radio Power Problem djak12 CJ YJ TJ and JK 7 07-20-2003 07:00 PM
radio on my yj mandarrin CJ YJ TJ and JK 13 07-20-2003 07:00 PM
 Subscribe to our RSS feed
